Torque Limits?
Old Mar 7, 2017 | 01:23 PM
F2502011's Avatar
F2502011
Torque Limits?
I keep hearing and reading about torque being limited in 1st and 2nd on the SRW and 1st on the DRW but haven't seen what it's limited to. What is the limit and is there a way to disable this?
Old Mar 7, 2017 | 01:53 PM
crewzer's Avatar
crewzer
Lightbulb
This article suggests the SRW diesel engine torque is derated in the first three gears.
HTH,
Jim / crewzer
Old Mar 7, 2017 | 02:18 PM
troverman's Avatar
troverman
SRW trucks are limited in 1st, 2nd, and 3rd gears for 2017. DRW trucks are only limited in 1st gear.
Nobody knows *what* the derating is, but is only affects torque, not horsepower.
Old Mar 7, 2017 | 02:31 PM
oklarado's Avatar
oklarado
I could be wrong but I don't think that's possible.
Old Mar 7, 2017 | 02:48 PM
troverman's Avatar
troverman
It's possible. Consider the Ford 3.5L EcoBoost - in the pickup, it put out 365HP and 420lb-ft (up to the second generation). This same engine, in all of its transverse applications (Ford Explorer, Taurus SHO, Lincoln MKS, etc) the exact same engine produced the same 365HP but torque was reduced to 350lb-ft. There are no differences between the engines internally.
Old Mar 7, 2017 | 03:10 PM
oklarado's Avatar
oklarado
Do those gas motors have a variable valve train? Also what about timing differences possibly. I'd have to see it from Ford to believe that a reduction in torque doesn't equate to a reduction in horsepower. Only think that could change is fuel and air right? Maybe I'm wrong but I'm skeptical.
Old Mar 7, 2017 | 04:49 PM
crewzer's Avatar
crewzer
Exclamation
The limit only applies to the diesel engine.
HTH,
Jim / crewzer
Old Mar 7, 2017 | 04:54 PM
silver_pilate's Avatar
silver_pilate
Really wish I had some of that derated torque in 1, 2, and 3. I guess I understand their reasoning...well, actually, no, no I do not. Are they trying to protect something in the drivetrain or are they worried about safety? Wish there was a way to turn this "feature" off from the factory.
--Nathan
Old Mar 7, 2017 | 05:00 PM
Strokin-A-2010's Avatar
Strokin-A-2010
If you switch the truck to "sports mode" doesn't that get rid of the detuning of 1st-3rd?
Old Mar 7, 2017 | 05:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You are wrong. They are talking about peak horsepower. Reducing torque at lower RPMs, which is usually what's done, doesn't affect the torque at max horsepower RPM, so the peak horsepower is unchanged. For example, if the engine makes peak torque at 1600 RPM and you limit torque at that RPM, and it makes peak horsepower at 3200 RPM, then peak horsepower is unaffected.
--Nathan
I didn't work on this truck, so all I have is an educated guess from doing this type of work at Ford.
The lower torque is probably due to a mechanical limitation somewhere in the drivetrain. It isn't done for fun, when I was there it was only done to keep from breaking parts. We found that customers really didn't like it when parts broke.
Old Mar 7, 2017 | 07:15 PM
oklarado's Avatar
oklarado
If you hammer down hard the motor has a real flat torque curve, way toward the top, so even if peak is unchanged it still has to lower the hp curve to an extent on the way up to peak.
Old Mar 7, 2017 | 07:36 PM
2009kr's Avatar
2009kr
Well, we know that if the HP is unchanged, then the derate is at max 100 ft-lbs. 925-100=825. 825*2800/5252=440 HP, so in order to get the peak HP, torque limit must be at least still providing 825 ft-lbs.
Old Mar 7, 2017 | 07:52 PM
Tom's Avatar
Tom
Ding ding ding, we have a winner! It's very simple math, folks...horsepower is nothing but torque at speed.
You could rephrase that by saying torque is limited at 2,800 RPMs...because if it made 925 ft-lbs @ 2,800 RPMs you would have 493 peak horsepower. You can't have one without the other.
Old Mar 7, 2017 | 07:57 PM
oklarado's Avatar
oklarado
I don't think its that simple, and I doubt its 825. 825 would still shred a ton of tires.
Old Mar 7, 2017 | 08:02 PM
85e150's Avatar
85e150
The link in post 2 mentions tire life.
