hello from Wisconsin
Old May 5, 2016 | 04:03 PM
  #46
hiball3985's Avatar
hiball3985
Thats strange, if you have a road draft tube you would have a pre 62-64 block. Trying to determine the HP would depend on what heads you have. Truck engines had lower compression heads as compared to passenger car engines..
Old May 5, 2016 | 04:38 PM
  #47
hardlyrider's Avatar
hardlyrider
Not uncommon (considering all the mods) to have a C2 series carb on an earlier block. Don't worry too much about it sitting for 12-13 years. Mine sat idle for 30 and it's running now. Check it out:
https://www.ford-trucks.com/forums/1...r-project.html
You're going to like the "Y"
Old May 6, 2016 | 09:01 PM
  #48
jaysam's Avatar
jaysam
Ok well the road draft tube would now make sense since i looked at the casting above the oil filter. The casting reads " ECZ 6015 C ". So again, with the little bit of research that i have done and if i read it correctly, its a 1957 312 or 292 depending on the main caps. So i guess i really cant tell for sure unless i open up the bottom end. Is that correct? Thank you guys for your help.........Jason
But i also read that '56 & '57 312's had 4bbl carbs, this one does not. So i'm gonna assume that its a '57 292
Old May 7, 2016 | 05:13 AM
  #49
Walston's Avatar
Walston
ECZ-C heads are good one's to have. The valves are bigger that the standard heads for a truck Y-block. This results in more horsepower. Post a picture of the water pump, with the pulley off and we can tell if it is a car or a truck engine. The truck engine has a larger shaft than the car engine had and the shaft sticks out farther.
Truck on the left, car on the right:
Old May 7, 2016 | 06:38 AM
  #50
jaysam's Avatar
jaysam
Yeah I'm not sure what heads are on it. I'll have to see if I can find where the casting #'s are on the heads. It wouldn't surprise me that with nothing matching or being stock that maybe they are different heads than the block. I'll get a pic of the water pump. Thanks Walston.....Jason
Old May 7, 2016 | 11:03 AM
  #51
jaysam's Avatar
jaysam
Old May 7, 2016 | 11:16 AM
  #52
jaysam's Avatar
jaysam
Walston, thanks for the info. According to the water pump shaft it appears to be a truck engine. Im still looking for any casting #'s on the heads. Alot of grease and grime. Are the head cast #'s readable with everything assembled in the truck with the exhaust manifolds on?
Old May 7, 2016 | 11:22 AM
  #53
Walston's Avatar
Walston
If I remember correctly the head numbers are under the valve covers. Try removing a cover. I agree it is a truck engine. Mine is a 60 and the vent tube goes out the rear. Check where the crank case vent is located.
ibboonie
Apr 16, 2017 02:08 PM
JPMallory
30
Feb 2, 2014 03:46 PM
Cochip
16
May 21, 2012 08:44 PM
ChugginAlong
Virginia Chapter
Mar 10, 2012 05:55 AM
v0mitus
Feb 17, 2011 03:27 PM
