Oil problem
Old Apr 26, 2016 | 05:48 PM
squaredancer's Avatar
squaredancer
Oil problem
Discovered to my horror that I've been topping up with regular synth oil vs diesel synth oil. Any thoughts on this? It hasn't caused any problems that I'm aware of just that I seem to be topping up more regularly.
Old Apr 26, 2016 | 05:54 PM
Bonanza35's Avatar
Bonanza35
Dump the oil as soon as you can. It isn't rated for are engines or diesel engines as far as that goes, it will cause greater ware threw out your motor. Also it will foam in the high pressure side of the motor more then what your suppose to use. I wouldn't make a habit of what your doing.
Old Apr 26, 2016 | 06:16 PM
Pirsch Fire Wagon's Avatar
Pirsch Fire Wagon
Originally Posted by squaredancer
topping up
Do you mean "Topping Off"?
I don't know how much you use. Do you have an idea?
A quart or so is no big deal. More than a few and you need to change it out.
Cell's
15
Mar 14, 2014 05:47 PM
sportsfreaked
6.4L Power Stroke Diesel
Jan 4, 2011 11:00 PM
Moby Dick
Jul 6, 2010 07:45 PM
coloradokid
Dec 18, 2007 12:32 PM
bad ass diesel
Nov 5, 2004 06:05 AM
