6.0 Rebuild [2005]
I bought this motor to build a reliable 6.0 for when my current running 6.0 goes [224,000 miles]
My goal is to build a fresh reliable 450-500hp motor.
So my question is, what needs to be tested on this motor to see what needs to be rebuilt or upgraded? I've built motors before, just never a 6.0 and never a diesel. What should I change out or upgrade while the motor is being ripped apart on an engine stand? Any recommendations on upgrading the valves, different pistons, boring? Any advise will be greatly appreciated.
Thank you,
-Jeremy.
You could be the first to volunteer for a 6.3L short block, :
6.0 Powerstroke Remanufacturing - J&K Engine Repair
Inside the ?6.3L Power Strokerrr??J&K Engines All-New, Ford V-8
Or get an Ashville Performance 20/30 with a cam:
Asheville Engine Rebuilders - Home
As far as I can tell it's pretty straight foreward. As always, total tear down and cleaning, cam bearings, don't forget the oil galley plugs. **** block deck prep. Cylinder finish is crucial, it's pretty common practice to bore AND hone with a deck plate installed, necessary on these engines I think. Skip the "do it yourself" ball hone on this one.
Several options for aftermarket cams now. Planning a good combo is important as far as cam, valve springs, injector size, turbo/boost level and tuning as well as supporting mods like intake and exhaust. Speaking of intakes, there are some cool (yet expensive) options for those now. Some places open them up and hog them out, I like extrude honing (porting). I've yet to see anyone build a 6.0 intake from scratch but it looks doable to me and there may be some out there.
The bottom end is pretty tough, I think just freshening it up will be fine for the HP numbers you're shooting for ( intake mods are probably unnecessary also, sorry for the sidetrack). Don't take the smallest ring off the back of the crank (inside ring of bolts on the face of the flange), it's matched to the crank, machined in position, and it could eat rear seals after reassembly or even vibrate even if you reinstall it in the proper orientation.
The new pushrods are .050in shorter to reduce preload on the lifters. They won't reduce gross lift and are a good idea on a fresh motor.
I know you already have an engine but a later model would be the best starting place. In addition to improved HPOP and plumbing, the later "commonized" engines have revised locations and sizes on the injector hold downs and hardware as well as rocker positions and hardware. They also have a different front cover with larger water pump and probably some more revisions I'm forgetting (someone will be along to straighten me out soon
). Back to the machine shop for a minute, new guides are a great idea but I like the bronze guide liners. They can be installed in the existing valve guides if they are within size specs or installed in new guides if you prefer. Hopefully the crank shaft will spec out after polishing. Cross drilling, chamfering, and nitride are options but again, not necessary for your goals. The cylinder head and block deck surfacing I'd like to see done on a mill with a flycutter rather than the more common surface grinding with a machine that uses a stone wheel. Port matching the intake and exhaust to match a good set of gasket is almost allway a few free ponies. You may be surprised at how badly the ports line up on some engines, and while you're right there with the grinder, removing any casting flash you can find (especially inside the ports) is a good idea.
It's fun and satisfying to assemble an engine yourself, ring end gaps, torquing and prelubing everything is a great piece of mind when you're firing it up for the first time but much of the important technical stuff is in the Hands of your machinist...choose wisely.
These are just a few random thoughts, my mocha latte with an extra shot is kickin in right now
There's a lot to consider on this subject.
So who is the machine shop to trust these days?
Ford's process is in this video at 2:15-ish:
https://www.youtube.com/watch?v=0HB5...ature=youtu.be
If you want to make 450+HP you're going to need the upgrades at some point, why not start with them? An Asvhille Performance 30 Coated longblock, Warren Diesel 155cc/30% injectors, and a Powermax or KC Turbo Stage 1.5 and you'll be where you want and then some. That's not the cheapest way to get to the power level you said earlier, but you're starting with high quality parts.
If your power goal was "eh stock is fine", Ford reman short block would be fine because other than studs you don't need anything else to add it it, and the basic block can handle stock power levels for hundreds of thousands of miles.
