Rear Axle Question
Old Apr 24, 2016 | 01:06 AM
gfoster82's Avatar
gfoster82
Rear Axle Question
I have a 2001 E350 with a dana 60 full float rear axle with 4.10 gears that needs to be replaced, can I swap it to a dana 60 semi float axle with 4.10 gears without any problems?
Old Apr 24, 2016 | 01:34 AM
gman97005's Avatar
gman97005
No, you can convert SOME of the semi-floating axles to full-floating but not the other way around, at least not that i know of..
If you could convert to semi-floating axles you would lose a lot of axle strength and load capacity..
Old Apr 24, 2016 | 01:38 AM
gfoster82's Avatar
gfoster82
I would be replacing the complete rearend.
Old Apr 24, 2016 | 01:40 AM
gfoster82's Avatar
gfoster82
This is what I would get
THIS IS A BRAND NEW DANA 60 SEMI-FLOAT REAREND FOR A 2001-2004 FORD E-250 AND E350 VAN WITH SINGLE REAR WHEELS. IT IS A 4.10 RATIO WITH THE FACTORY POSI. INCLUDED ARE THE AXLE SHAFTS AND ROTORS. THE HOLLANDER NUMBER IS 435-2188C. THE SPICER BILL OF MATERIAL NUMBER IS 606023-6
gman97005's Avatar
gman97005
that would work fine..
Old Apr 24, 2016 | 01:45 AM
gfoster82's Avatar
gfoster82
Would I lose any load capacity,I have a lsd now would posi be better?
Old Apr 24, 2016 | 02:24 PM
vettex2's Avatar
vettex2
How much $$$ ?
Old Apr 24, 2016 | 04:05 PM
fordman75's Avatar
fordman75
Yes the semi floating axle rear has a lower capacity then the full floating rear diff. The semi floating rear has one bearing per side and it rides on the axle shaft. The full floating rear has two bearings per side and they ride on a spindle. It's much stronger then the semi floaters.
LSD, posi, same thing different term.
If you do the swap and are in Minnesota, I'd be interested in your old diff.
Old Apr 25, 2016 | 01:20 AM
6.0Vanman's Avatar
6.0Vanman
OP, I'm doing the exact opposite swap on my 4x4 van. It should be plug and play and you can simply bolt on your old brakes if the donor axle is 99 or more recent. You'll want to make sure it's also from a van so the bolt pattern is the same (ie., 6.5/8). You may need a shim or two on the spring perch to line up the pinion.
I don't think Woodberry is anywhere close to Arizona but I'm going to have a semi-float D60 with 4.10 gears for real cheap in a week or so.
nash22
Oct 1, 2011 11:57 PM
Super Wagon
13
Aug 3, 2011 06:44 PM
PsD007.3
Feb 24, 2010 09:51 AM
jmono
Apr 30, 2006 12:26 AM
79_250RangerLariat
Jan 5, 2006 06:54 PM
