New FICM issues.
Ok so I am going to put you on the spot on this one. You said that you have
changed the procedure and now test before they go out the door. Why was
this not already in place? Before I got in to aviation I would test before return
to service just for my peace of mind. Now that I have trained in that field I
would never think to release anything without a final service test before I ever
thought to return to service. The fact that you have changed this is good.
We build exchange clusters to inventory, and the past process was to test as a "final" step before putting them on the shelf. This wasn't always the final step though if we loaded a PHP tune into the FICM once an order was placed. This was the first time we ever had a problem with a tune not loading properly. Our process for R&R naturally followed the same sequence - the repair technician did the bench test before and after repair along with a truck test as a "final" test before sending it to shipping. When this happened, we quickly realized that there had to be another run on a truck after any programming was performed.
I think it will more that pay for it's self even if it never happens again.
Because you know that it's been tested after all work was done.
Sean <BR>
6.0L Tech Folder
#56
Carlosfj80's AvatarCarlosfj80 , Today 11:12 PM
P0611
I'm new to Fords and new to the forum, been a Toyota guy all my life. Been getting a P0611 code when I run a scan with my SCT3015. I have not noticed any power loss or starting issues. All though it takes a 1.5 seconds to start. Truck runs great, fuel mileage is no better than 14 Mpg even with a "Canned" street tune from my SCT. No CEL by the way, only reason I noticed is before I updated my tuner I ran a DTC scan and the code came up.I had a friend plug his CPU in and I was getting 48v when the truck was warm, it did drop to 46-47 for a second or 2. I clear the code and everyday it comes back. What am I looking at here? I hear the injector chatter every morning before it starts. Will check the relays tomorrow. I have a local mechanic who will rebuild and remove/install for $435 with a 2 yr warranty.
What do you guys suggest, what should I be looking for?
Thanks in advance!
Edit Reply
#56
P0611
Thanks in advance!
Edit Reply
These guys at CBM made my FICM great. Consistent 48V, tune works great and it came back to me looking like it was new.
is who I would go with for a FICM.
Cluster or overhead display then CBM.
Sean <BR>
6.0L Tech Folder
Thanks in advance!
Edit Reply
We offer a rebuild service as well as an exchange service on those FICMs. We give a 5 year warranty and offer the PHP tune upgrade. They are a great option.
6.0 Powerstroke FICM Repair - FICM Programming Upgrade
If you are new on the Powerstroke scene, spend some time digging through these forums. It's well worth the time. Lots of good information passed along.
I am studded(bought it this way with records), apr studs with newer oil cooler, egr delete, coolant filter, basic bulletproof. I did all the oil and fuel filters using motorcraft brand and rotella t6 5w40 2 weeks ago.
Reach under the unit and push up on the first plug.
Squeeze the locking table and then pull down.
Be gentle and it if hangs you need to push back up and try again.
Where is can became a PITA is installing after you have moved the
harness around and that is a given for most work. Before you drop
the FICM back down take a little time to settle the plugs and get them
lined up. That will help a lot. Then start each plug and push. You want
to hear a "CLICK" as they slide home. Take the time to tug back down to
make sure that they really have locked into place and that one step will
save you some diagnostics headaches down the road.
Sean <BR>
6.0L Tech Folder
cut it open and take a magnifying glass and check for craters
and burns.
Best way to test is to put it under a load and see how much
voltage drop it has. The switched side of that relay has a 50A
fuse so a draw of 45A should give you the amount of drop that
you might see when installed into the truck.
50A X 12V = 600 Watt. You would think it more but that is what
you get. A 0.24 Ω 100 Watt resistor will give you the needed current
to verify the drop of the relay contacts.
You can also use this test found here >>> How to Test the Voltage Drop of a Relay Contact - Diagnostic News
The easiest option is to just replace the thing.
Sean <BR>
6.0L Tech Folder
and burns.
Sean <BR>
6.0L Tech Folder
This covers some very special tools that I know that FICMrepair has.
I know with Ed you are also getting a full testing before it leaves. There some upgrades
that are done. Your local guy most likely is putting a Dorman (Made in China) power board
in it. You know how the stuff from China comes in cheaper? Two things they never did
the design work and they use cheap low cost parts.
Save yourself a stuck on the side of the road late at night and just go with
FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
You will be happy you did.
Sean <BR>
6.0L Tech Folder
As has been said, removing the FICM is not that complicated. Installing it isn't bad either. If your mechanic is indicating that $140 of the $435 is in parts, he is indeed assuredly buying a replacement power board and hoping that that solves the issue. While it may, a significant percentage of FICM issues are with the other side of the module - the logic side. Conveniently, we work on both sides.
If your local guy changes out the power side and it indeed solves the problem, I suppose that you are set. The question is what happens if that doesn't solve the issue.
All of this said, don't let the tuning bit enter into the equation for you. You can always get the Atlas 40 or any of the other tunes installed on whatever module you end with - whether from us, your local source, from PHP directly, or from one of their other dealers.
If you've got a 611 code, the one thing that you do know is that the FICM isn't performing as it should. The questions now are what is wrong with it, who do you want to have work on it for you, and (likely the biggest question yet) why are you having this issue in the first place? Regardless of what path you choose to get your FICM operating again as it should, PLEASE ensure that you yank your alternator and batteries to have them tested on a bench. There isn't much sense in going through the financial pain here only to have a recurrence of the same issue as a result of the foundational issue that created the FICM issue not being dealt with.
We've helped literally thousands of FTE members over the years with their FICM issues. We aren't the least expensive option out there but are far from the most expensive too. We'd be delighted to add you to the happy customer pile. If you'd like to visit about the litany of options, please feel free to give us a call. We're at 515-897-4459.
Good luck!
