Spindle nuts on the front axle
04-23-2016, 11:25 AM
on
F250 7.3 solid front axle looking to find out the proper way to tighten the spindle nuts thanks for the help
04-23-2016, 07:01 PM
There's a socket for it. Good luck figuring out which one it is at the parts store as they literally have no idea. At least at the one here.
04-23-2016, 09:24 PM
on
Quote:
Originally Posted by
Kingkong0192
I need to know the torque specs
04-24-2016, 10:34 AM
Do you have the spanner nuts with the four notches for the manual hubs, or the big hex nut for automatic hubs?
04-24-2016, 10:42 AM
on
I have the spanner nuts with the four notches
04-24-2016, 01:01 PM
Does it have 4 or 6 notches
04-24-2016, 01:14 PM
on
I just need to know the torque specs for the inner spindle nut to titghen the wheel Barrings
04-24-2016, 02:15 PM
on
04-25-2016, 04:56 PM
on
JAFO1
There are no torque specs on this tho for the spinel nuts just need the torque specs so I can do my wheel barrings
04-25-2016, 07:07 PM
on
1993ford
Okay, sorry. I thought the information was down toward the bottom of that pdf.
04-25-2016, 07:09 PM
on
JAFO1
Thanks anyways tho
04-25-2016, 09:29 PM
Torque the inner nut to 50 ft. lbs, to seat the bearings. Back it off and re-torque it to 30-40 ft. lbs. While rotating the hub, back it off 90 degrees. Put the lock washer in with the key in the groove of the spindle and check for alignment on the lock pin on the inner nut. Tighten the inner nut until the lock pin lines up with the nearest hole on the lock washer. Put the outer nut on and torque it to 160-205 ft. lbs.
04-26-2016, 01:41 AM
JAFO1
It's there.
wannabe7.3
02-07-2015 10:09 PM
chiefsfootball
01-20-2015 02:18 PM
jeep_guy48
08-26-2012 09:13 AM
Rob Peterson
1999 to 2016 Super Duty
11-01-2005 02:50 PM
Hottemp
08-07-2003 08:27 PM
