Going to put new shocks on the rear. I will need to cut the old ones off at the upper mounts. Question can I just get new boots to mount the new ones or will I have to get new shock mounts?
heat it up and use some PB blaster or something. apply it a few times with in 24 hours and try to remove it with a impact. or grind the rivits off the frame on the outside. and get a new shock mount. I just did that but the bed was off. Mine were junk and rusted in parts.
Looking last night, it looks easier to grind off the rivets and put new brackets on. They are in pretty bad shape anyways. Might as well do it now instead of later when it brakes. Looks like the brackets are only $14 or so.
