warn hub installation problem
Old Jan 18, 2015 | 07:22 PM
chiefsfootball's Avatar
chiefsfootball
I purchased some new warn hubs. I got one in, but on the other side, I can't getbit in far enough to install the outer snap ring that holds it in. It just hits the axle nut and won't go in further. Any idea what's up?
Old Jan 20, 2015 | 12:42 PM
JEFFFAFA's Avatar
JEFFFAFA
On later model trucks I know that automatic locking hubs and Warn manual hubs take different axle nuts. So I am assuming that is ALSO your problem. One side had a comparable axle nut and the other side does not. My brother once bought a Chev Blazer (78ish) that the PO had a warn hub in one side and a FORD hub on the other. So it is possible your truck has two different axle nuts. I would contact who you bought the hubs from and buy a Warn axle nut.
Old Jan 20, 2015 | 02:18 PM
chiefsfootball
I figured it out. I just needed to tighten down the axle nut so I could put the hub in further! Thanks for the response!
wannabe7.3
Feb 7, 2015 10:09 PM
mich800
6.4L Power Stroke Diesel
15
Aug 22, 2014 07:45 AM
rojami
Dec 17, 2011 06:40 PM
ganzey
Jan 27, 2011 09:48 PM
Rhodey460
Oct 20, 2005 01:22 PM
