'97 E-Super Duty Extra connector under dash?
Old Apr 22, 2016 | 02:55 PM
ke5eua's Avatar
ke5eua
I have a '97 motorhome that is on a '97 e series chassis. The body of the coach is soon to be removed and replaced with a flat bed for hauling motorcycles. In preparation I've been figuring out fleetwood's wiring.
Now I have the standard brown trailer connector under the dash but above it I have a grey 6 pin connector and can't seem to find any documentation on. Ford doesn't have the electrical part of the upfiters for the '97 year van chassis on the fleet site.
Any insite?
My goal was to be able and plug an apcm to the chassis for idle control but it being a 6.8 gasser I don't have the port like I did on my 7.3.
Here are some pictures, hopefully someone knows what this is.
Old Apr 23, 2016 | 11:22 AM
ke5eua's Avatar
ke5eua
No one? Anyone?
Old Apr 24, 2016 | 06:51 PM
Todd Rasmussen's Avatar
Todd Rasmussen
plug under dash
looks like the trailer brake, plug , harness end , same as on my 2002 f250,,v10 pretty sure it is,, to hook up brake controller,,
Old Apr 24, 2016 | 06:54 PM
ke5eua's Avatar
ke5eua
I know one is the brake controller plug, but the other?
Old Apr 24, 2016 | 07:01 PM
Todd Rasmussen
,,, oops my bad,, didn't look at pic.s as much as I should have,, yea you have 2 , grey and brown ,, not sure what other one is , hopefully , someone will chime in with better knowledge of your rig,,
Old Apr 24, 2016 | 07:14 PM
Todd Rasmussen
under dash plug/ harness
this would do a lot better in a different forum, towing , - other brakes ,electrical, maybe post it there,,
Old Apr 24, 2016 | 07:17 PM
ke5eua's Avatar
ke5eua
If an admin would move it to the appropriate section by all means please do.
Old Apr 25, 2016 | 08:46 AM
LxMan1's Avatar
LxMan1
Moved to the correct forum. Yes, the 6 pin plug is for the trailer to package when using an electric brake controller. Most auto parts stores sell the harness to plug into it and then wire into the brake controller. You should have a factory 7 pin plug in the rear bumper if equipped with the tow package.
Old Apr 25, 2016 | 08:58 AM
ke5eua's Avatar
ke5eua
I know one is the brake controller plug, it's the other one I don't know what goes to.
I thought I explained it we'll especially with the pictures.
Old Apr 25, 2016 | 12:29 PM
JWA's Avatar
JWA
That vacant connector might also be originally intended for a rear area heater & A/C unit---the colors look vaguely familiar with that system. See if there's a free online schematic of the trailer brake connections and another for the rear area heater.
Even though this cab & chassis found use as an RV I'm wondering if it wasn't originally outfitted from the factory with extra wiring and connections, its final use not known, things like this added for maximum flexibility and quick sale to upfitters?
Old Apr 25, 2016 | 12:33 PM
ke5eua's Avatar
ke5eua
I'll look into that. I know the vin sticker says equipped with rv package and not to be used as an ambulance.
Whitey5.0
Oct 14, 2017 05:09 PM
parcours
2009 - 2014 F150
Apr 11, 2016 06:34 PM
Chris 56 f6
18
Apr 16, 2015 09:48 PM
queen of spades
Mar 31, 2015 11:15 AM
storchmj
Mar 17, 2015 07:00 AM
