Wiring Question
Old Apr 20, 2016 | 02:06 PM
Baatzy's Avatar
Baatzy
Wiring Question
Hey guys, I am looking at putting a couple small LEDs in the pinch weld area under the doors on the cab. I want to have them come on when I open up a door. Where is the best place to grab power from the door switch circuit for that? The passenger side I was thinking of grabbing it where it goes into the sleeve between the cab and the door, but on the drivers side there are a lot of things in the way to get to that point. Can I pick it up down in the door jamb area? Is there a wire going to the dome light there?
Thanks,
Baatzy
Old Apr 20, 2016 | 02:14 PM
empiretc's Avatar
empiretc
tap into the door switch.
Old Apr 20, 2016 | 02:46 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
You can get LED strips in any color. Splice into the lower door light. You can buy a big roll of the LED's on Amazon cut them to length and solder on wires after removing coating. Use a little super glue it will compliment the adhesive that is on the back of the strips. Holds a little better than just by itself.
Old Apr 20, 2016 | 02:59 PM
Pirsch Fire Wagon's Avatar
Pirsch Fire Wagon
deleted deleted
Old Apr 20, 2016 | 10:53 PM
Baatzy's Avatar
Baatzy
I have the LEDs I plan on using, we'll see how they turn out. I may turn to an LED strip like described. One of my final projects is dealing with RGB LED strips so I have a few options if needed.
Where can I tap into the door switch at? Also, I don't have any wiring diagrams, so does anybody know what color wire I am looking for?
Thanks,
Baatzy
Old Apr 21, 2016 | 04:54 AM
Whitey Ford
The LED strips cost like $7 for 4'. Cutting to length and solding new leads on is an art, but the light they emit is well worth it. Not sure why you wouldn't tap into the existing door light but maybe you do not have one.
Old Apr 21, 2016 | 08:28 AM
bigb56's Avatar
bigb56
Doesn't the door switch just switch the ground half of the circuit?
Old Apr 21, 2016 | 08:35 AM
Chevota_72's Avatar
Chevota_72
Yes the door switch is a grounding circuit. As mentioned earlier you could tap into the wires going to the courtesy light on the lower door panel if your vehicle is equipped with that light. Or you could install a relay and have the door switch ground the coil on the relay and turn on your new LED lights.
Old Apr 21, 2016 | 09:25 AM
Baatzy's Avatar
Baatzy
I get what you are saying about the courtesy light now. I could, but my lights are a round hole mount style. I would like to give them a try first as I think they will have a longer life than the strip style LEDs. I spend a lot of time on gravel and in different fields and have no mud flaps of any sort so the bottoms of my doors spend a lot of time filled with mud and other junk. That makes me not want to drill holes in the bottom of the door, or hope that a sticky strip is going to stay in place. Where as the pinch welds see a lot of mud and other junk as well, but it generally drops off.
I may end up there, but for now I would like to pull it from the cab if possible.
Baatzy
Flyview
Jul 9, 2017 08:35 PM
PMDRACER
Jun 14, 2015 06:54 AM
polarisman
2004 - 2008 F150
Apr 22, 2014 11:48 AM
jprix
Jan 8, 2014 11:20 AM
StevensPoint
Nov 29, 2007 08:10 AM
