vibrates in reverse
Old Aug 13, 2003 | 07:52 PM
Frozen1's Avatar
Frozen1
vibrates in reverse
Hi folks,
Lately I've noticed a vibration noise from the rear end if I back up too quickly or climb a hill in reverse. I've always had a clank whenever I shift into reverse but it's not too bad. Could this be part of the problem?
I've never done any rear end work and I'm not sure how to diagnose the problem. I'd appreciate any help.
Thanks,
Jon
Old Aug 14, 2003 | 04:09 AM
Torque1st's Avatar
Torque1st
Posting Legend
vibrates in reverse
I assume this is the truck in your sig... If so I suspect your tranny is about to go south.
Old Aug 14, 2003 | 10:09 AM
Highboy70's Avatar
Highboy70
vibrates in reverse
Could also be the tranny mount or the carrier bearing and mount(if you have a 2wd), maybe even a broken motor mount. I'd check all those first. Also retorque your rear spring mounting bolts.
Cheaper and easier than a tranny.
Old Aug 14, 2003 | 01:31 PM
dfisher1's Avatar
dfisher1
vibrates in reverse
All,
This is a combination of problems:
A shaky rear end while backing under power is a underdamped suspension problem. (i.e. replace your shocks and add a leafspring).
The clunk is the driveshaft slamming into or out of the tranny. A soft rear end allows the diff nose to rotate up or down depending on a (reverse to drive) or (drive to reverse) shift.
It is common on 1/2 tons as the springs have weakened/fatigued over the last 30 years.
I'll bet if you loaded the camper special up until the second stage springs engaged you could minimize the clunk.
Consider it,
KingFisher
Old Aug 14, 2003 | 05:44 PM
Frozen1's Avatar
Frozen1
vibrates in reverse
Well, I think I'll try Highboy70's suggestion and check my rear spring mounting bolts and tranny mount first. I don't think that's the problem, but it sure beats Torque1st's diagnosis. I can't afford another tranny right now.
I also doubt that an underdamped suspension is part of my problem as dfisher suggests. In fact, I would say that my rear suspension is a little too rigid. Also, my truck doesn't shake or hop when I'm backing up under power, it just makes a vibration buzz.
If my tranny is about to die as Tourque1st suggests, what are your recommendations? Are automatic transmission problems something that the average backyard mechanic can tackle by himself? This is my daily driver and it will start to get cold here in Alaska near the end of Sept. If I'm gonna fix my tranny, I'd better start soon. Suggestions?
Jon
Old Aug 18, 2003 | 06:26 PM
Highboy70's Avatar
Highboy70
vibrates in reverse
Jon,
Sounds like were in the same neck of the woods. I live in North Pole. Just moved from Fairbanks.
If you do end up needing a tranny, you might have better luck finding a parts truck for sale around town.
I bought a 72 F150 4x4 with a blown motor this spring for $150, it had a standard tranny, but I got plenty of parts off it.
I do have lots of other parts too, so let me know if your looking for anything in particular. ralph.moore@eielson.af.mil
Ralph
Old Aug 18, 2003 | 06:56 PM
Frozen1's Avatar
Frozen1
vibrates in reverse
Thanks Ralph!
Next time I need a part, I'll email you before going to the store!
BTW, I checked my rear spring mounting bolts and tranny mount and everything was tight. I guess I'll just keep a close eye on my tranny and see what happens.
I'd love to buy a parts truck, I just don't have anywhere to put it. I live in a little 5-plex apartment complex. My landlord won't even let me change my oil in his parking lot, much less park a parts truck. Doh!
Jon
Old Aug 18, 2003 | 10:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
vibrates in reverse
FTE does not allow want/buy/sell/trade discussions on the boards. Please review the terms of use that you agreed to when you registered. The guidelines can be found at: https://www.ford-trucks.com/guidelines.html
Please use the classified ads and email for those inquiries.
Forum Ad guidelines:
No Advertising...
No Want AD's...
No For Sale AD's...
No "I have that part... E-mail Me"...
No "How much do you want for it?"...
No "Does anybody have one?"
No "What is this worth?"
...Posts of any kind!
Violations can result in suspension of posting priveleges.
Treacy
Apr 30, 2015 12:39 PM
VE290
Jul 20, 2014 03:35 PM
Tony Zurenda
Mar 28, 2014 01:45 AM
IndyDog
Aug 13, 2008 07:41 AM
