E4OD hard shift
Old Apr 16, 2016 | 09:36 AM
ridemech's Avatar
ridemech
E4OD hard shift
Hi guys I'm new to this forum and a little out of my element when it comes to efi ford's. I have a 92 f250 with 460 and electronic overdrive I am assuming it's an E4OD. When it's cold it is extremely hard shifting from 1 to 2 unless I shift it manually and it wants to down shift back to first at any speed under 50km/30mph. Sometimes the speedo needle drops of and shuts off cruise and now most recently it feels like it's either slipping in overdrive or hunting between overdrive and 3rd. I almost pulled the tranny out but after reading some of the posts here I'm thinking it could be in the cluster? Any advice is appreciated thanks!
Old Apr 16, 2016 | 10:34 AM
rla2005's Avatar
rla2005
Check for codes. The fact the speedometer drops and the cruise has kicked off indicates an issue with the VSS signal. It could be the VSS, wiring, PSOM. Process of elimination. Start with the code check first.
The computer uses the buffered signal from the PSOM to control the transmission.
Old Apr 16, 2016 | 11:11 AM
ridemech's Avatar
ridemech
Thanks I will check for codes tonight. The rear abs light is on as well, could that also be a clue?
Old Apr 16, 2016 | 11:19 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, that's also a clue that what rla2005 told you is correct.
trevorrules
Sep 29, 2015 02:33 PM
b4hntn
1978 - 1996 Big Bronco
72
Mar 11, 2011 07:03 PM
Cdy1
Jan 11, 2009 02:33 PM
johaner78
Sep 21, 2008 11:57 AM
mbertness
Dec 5, 2006 06:20 PM
