Posm trouble!?!?
Old Sep 26, 2015 | 12:29 PM
trevorrules's Avatar
trevorrules
Posm trouble!?!?
I got a 95 power stroke e4od tranny 4x4 . The transmission will act stupid causing irregular shift patterns , and the of light will begin to blink but no codes are being pulled up . It's seems when my truck sits out in the heat or I turn the heat on in my truck to max it will begin to shift in ways that I can't explain it does something different every time it starts to shift like 1st to 3rd them back to 2nd then 3rd then slams in to od that's the most common way it will shift , iv checked the vvs, the tone rings are good , the vvs was not scratched in any way , does this narrow it down to my psom ?
Old Sep 26, 2015 | 03:49 PM
subford's Avatar
subford
If your ABS yellow lamp is not on then yes it is more than likely is the PSOM or your speed control module.
Old Sep 26, 2015 | 05:26 PM
thehead406's Avatar
thehead406
I had almost the exact same problem except for the od light never flashed. I changed the vss, the connector for the vss. I pulled the main trans harness connector and checked it out. Pulled the psom unit from behind the speedometer and gave it a visual inspection. Put everything back together hasn't done it since. Still never figured it out but I don't care as long as it shifts fine.
Old Sep 26, 2015 | 10:40 PM
trevorrules
Abs light does not come on
Old Sep 27, 2015 | 08:18 AM
Briansshop's Avatar
Briansshop
MLPS, maybe.
Old Sep 27, 2015 | 01:33 PM
trevorrules
Originally Posted by Briansshop
MLPS, maybe.
Could the mlps cause shifting issues , I thought he only reason it's there is to keep the truck from starting in gear
Old Sep 27, 2015 | 04:02 PM
Briansshop's Avatar
Briansshop
Never had that prob myself, but seems I can remember reading about it causing that type of issue.
And it does function as a neutral safety, and back up light switch, and each position lets the ECM know what gear is selected.
Old Sep 29, 2015 | 02:33 PM
1995F150XLT4x4's Avatar
1995F150XLT4x4
I had a similar issue in my 1995 F150 5.8/E4OD. It was having erratic intermittent shifts.. very harsh/random gear changes and the OD light flashed. I replaced the VSS to no avail. Turned out to be the PSOM.
Truckie82
May 12, 2019 12:10 PM
mtnmx
Feb 2, 2017 10:58 AM
meb9796
Feb 11, 2012 03:27 AM
johaner78
Sep 21, 2008 11:57 AM
rockpicker
May 25, 2008 03:49 PM
