Surging crazy
Old Apr 14, 2016 | 12:46 AM
Shelleym62's Avatar
Shelleym62
Surging crazy
Hello peeps, I have a 2007 f350 6.0, just replaced the oil pressure sensor in January, now, my truck is surging like crazy! I heard it could be the ICP sensor, how easy is this to change? And where do I find it if this is the problem! Help! Sos
Thanks Shelley
Old Apr 14, 2016 | 02:20 AM
87crewdually's Avatar
87crewdually
You should post some data for a better diagnosis. Data such as ICP volts, ICP pressure, IPR% at the least when it's surging and idle.
For a quick test, unplug the ICP sensor and run it. It will run on a default. The ICP is on the top passenger side valve cover. Also inspect the plug for oil leaking from the sensor or weak wires. There are also replacement plugs available because they do go bad.
mattdoc88
Jul 31, 2018 11:35 PM
robjs111
Jan 6, 2009 01:27 PM
aocabrown
Dec 28, 2007 11:08 PM
roady891
May 28, 2007 09:16 PM
brad7.3
Aug 20, 2006 09:37 PM
