Oil on ICP sensor
Old Dec 28, 2007 | 05:35 PM
aocabrown's Avatar
aocabrown
Oil on ICP sensor
Pulled my ICP sensor to troubleshoot my idle issue. It had some oil on it. Not leaking anywher I can tell but just some oil on the insert portion of the sensor plug.
Is this a sign I should replace the sensor. I haven't gotten a good/cold start to verify if idle/perf issues could be sensor related but seeing the oil makes me wonder if the sensor is bad and should be replaced.
Thought?
Old Dec 28, 2007 | 05:39 PM
zx250's Avatar
zx250
Of the next Riffraff East
The oil people refer to that points to a bad sensor will be on top, under the plug. It means the sensor body has a hole in it and is letting the oil pass through it. HTH
Old Dec 28, 2007 | 06:17 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
thats a faulty ICP sensor, get a new one on ebay, just a mater of time till you have problems with it, and this might be you idle issue. thats what Jody from DP told me and Joey from Terminator
Old Dec 28, 2007 | 07:53 PM
F350-6's Avatar
F350-6
Have you tried unplugging the ICP to see if that clears up the idle? If it does then I'd say you need a new sensor. Just remember the truck won't run right with the ICP unplugged.
Old Dec 28, 2007 | 11:08 PM
jtharvey's Avatar
jtharvey
From everything I've read on here, that's a sure sign that the ICP is going out. You'll want to replace it.
Edit: Here's one for you on eBay for $60, which is about half of what the dealer charges. Item number 130185291235 if the link below doesn't work. Only 16 hours left in the auction.
http://cgi.ebay.com/ebaymotors/ws/eB...1235%26fvi%3D1
jeepnatv4life
Sep 22, 2015 05:48 AM
Firefighter 1406
Mar 19, 2015 07:27 PM
cutlass
28
Jan 4, 2014 11:07 AM
n20
Nov 6, 2009 08:20 AM
Smokey1
Oct 10, 2007 10:47 PM
