So just got a new pcm installed since i fried the last one anyway
i had a new trans installed almost two weeks ago factory 4r100 now i have a p0720 code. Id take it back to that dealer but id rather put fireball in my *** so im just going to fix it myself
I cant seem to find a part price though for the sensor or some trouble shooting things to do before buying another part since ive had my truck two days in the past month,
EDIT if i woulda searched more i found a price at advanced auto.. but id like to trouble shoot before i replace
The first thing to do is check the the wiring is actually plugged into the sensor. If the code comes shortly after a new trans is installed that's usually the problem.
Haha well my trans went on my home down to de since my wife and son are in pa. I work in de so closest dealer got it but they dicked and dicked around but either way
Whelp crawled under this afternoon OSS plug wasnt right the Green wire was not in the plug so pulled it back some and re connected all problems solved will most likely get a new connector this weekend since i just shoved the wire in there
The collective knowledge on this site and the willingness to help makes it so awesome
And well worth any money I've spent to be a member!!!!
