Trans code P0705
Old Oct 5, 2013 | 01:00 PM
DavidE's Avatar
DavidE
Trans code P0705
Can someone pls help me with the meaning of trans code P0705. On the index of trouble codes it says "trans range sensor error". Is this serious? Does this mean I shouldn't drive very far and should get it checked out and repaired immediately? Or is it OK to drive as I'm 600 miles from home? Any help appreciated!
Old Oct 5, 2013 | 07:20 PM
lowbed dud's Avatar
lowbed dud
sorry no help, just a bump back to top
Old Oct 5, 2013 | 07:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If it shifts through all the gears it will probably be fine getting it home.
Old Oct 6, 2013 | 12:56 AM
DavidE's Avatar
DavidE
Thanks Mark. Looked at the wire harness connector and seems OK. Undertsand if it isn't shifing OK will need to look at changing the sensor or having continuity of wires checked out. Last first.
Old Oct 10, 2013 | 11:18 AM
DavidE's Avatar
DavidE
Cleared code and drove 600+ miles home with no shifting problems or reappearance of any trans codes. Trans temps same as before too. Wonder if initail code could have been triggered by driving several hours into headwinds gusting to 60mph with camper on?
Old Oct 10, 2013 | 04:57 PM
Mark Kovalsky
No, I can't see how that could make a P0705 code appear. An intermittent wiring issue could it.
ncshovelhead
Jun 16, 2022 10:52 AM
Dave Bitton
1997 - 2003 F150
May 24, 2017 09:07 AM
Dave Bitton
1997 - 2003 F150
May 23, 2017 03:42 AM
