Sponsored by: Real Truck
Stator lock in?
Old Apr 10, 2016 | 01:22 PM
prkranger's Avatar
prkranger
Stator lock in?
why does the stator unlock every time I let of the gas on my 2004 6.0, I have been trying to increase the gas milage on my truck and to me the number one problem is that every time I let of the pedel the stator unlocks increasing my rpm by 400. in my chevy the stator only unlocked if I touched the brakes or down shifted.
Old Apr 10, 2016 | 02:10 PM
99f350sd's Avatar
99f350sd
You mean the torque converter. Stator is in the alternator LOL. Its not supposed to do that imo. Maybe a trip to the local ford shop. Prob have to put a scanner on it.
Old Apr 10, 2016 | 02:13 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The reactor stator is part of the torque converter.
No, your RPMs shouldn't jump from letting off the pedal. Does the Tow/Haul light ever flash?
Old Apr 10, 2016 | 02:35 PM
99f350sd's Avatar
99f350sd
What he said...torque converter clutch..stator reactor whatever.lol
Old Apr 10, 2016 | 04:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The torque converter clutch and the torque converter stator are two separate parts inside the torque converter. It's your converter clutch that is unlocking when you lift off the pedal.
It's done that way in the software by design. Yes, it is supposed to do that. The easiest way to change it is to get a custom chip that eliminates this.
Old Apr 10, 2016 | 07:06 PM
99f350sd's Avatar
99f350sd
My 99 doesn't do that. my 96 aerostar might..
Old Apr 10, 2016 | 07:18 PM
prkranger's Avatar
prkranger
Mark, why would it do that. It seems counter productive at least for fuel economy.
Old Apr 10, 2016 | 08:45 PM
Mark Kovalsky
The short answer is that management liked it better that way.
We found a condition where we needed the converter to unlock with the go pedal released. If you are power on with the converter locked and quickly drop the go pedal, then quickly get back on it, the truck will go into oscillations. I went for a drive to duplicate this because we had a customer complain about it. It was AMAZING! I thought I was holding my right foot steady on the go pedal, but the data showed I was rapidly pushing it down and letting it up. The truck was jerking back and forth rapidly. I had things in the cab flying all over! I've never seen anything like it. I then changed the program to unlock the converter when the go pedal was released and I couldn't make this happen again. Went back to the staying locked program and I could make it happen every time.
I proposed a software change that only unlocked when it recognized this condition, but I was shot down. The early '99s did stay locked, I don't remember when it was changed to unlock at closed pedal.
Old Apr 12, 2016 | 07:57 PM
prkranger's Avatar
prkranger
Mark thank your for the response, Great information. So I assume I would be better off leaving it as it and not having a custom program written.
Old Apr 13, 2016 | 11:04 AM
99f350sd's Avatar
99f350sd
Mines a 3/3 98 f350 that's way early.
Now that I think about it when coasting downhill in my aerostar I often hit the
unlock button to slow me down so I don't have to use the brakes...rotors too small issue. So it stays locked.
Old Apr 13, 2016 | 02:35 PM
Mark Kovalsky
This would take a lot more than custom tunes, it would take custom software to change the operating system. It would be very involved, and if you could even find someone that could do it, it would be very expensive.
Old Apr 13, 2016 | 05:02 PM
prkranger's Avatar
prkranger
Thanks again Mark, I am a little confused because you said earlier that it could be done with a custom chip. ?
Old Apr 13, 2016 | 07:54 PM
Mark Kovalsky
You can get it to stay locked with a custom chip. I was then talking about the modification I tried to make in the production calibration and got myself confused.
hytekredneck
May 26, 2008 09:14 PM
rcevans
All Things Towing
Nov 27, 2006 01:50 PM
JimBrazil
Jul 3, 2005 09:58 PM
Quadzilla
Apr 28, 2002 08:57 PM
