Quick Question - Axle U-Bolts
Just installed a "Nostalgia Sid's" 2" Dropped Axle and dropped by C&G for new U-Bolts all around. I don't have a Manual but after a search, it appeared the torque spec was 108-125 lb/ft in a criss-cross.
After cranking the Axle down @ 115, I thought it wise to question if that clamping force (which must be enormous) would crush my '60's 9" Housing Tube? Is the torque spec the same for front and rear?
Thanks as always.
Dawg-a-saurus
Thanks as always.
Dawg-a-saurus
You may be able to measure it where the vent assembly screws in, if you remove the vent. My guess would be around .100".
Occasionally you can see a truck going down the road in front of you doing what we used to call "dog tracking" usually due to a loose U bolt connection.
I probably average replacing at least one set of springs each month and 4x more spring pins. We keep about ten sets of springs on hand and service around seventy trucks/engines.
Thanks!!
More than likely the center bolt through the spring has sheared its head first then the u-bolts loosen as the axle slips back and forth over the spring.
'94IDITurbo7.3
25
05-14-2014 08:38 AM
TexasGuy001
07-05-2006 12:48 PM
