Quick Question - Axle U-Bolts
Old 04-07-2016, 08:53 PM
eman92082's Avatar
eman92082
eman92082 is offline
Just installed a "Nostalgia Sid's" 2" Dropped Axle and dropped by C&G for new U-Bolts all around. I don't have a Manual but after a search, it appeared the torque spec was 108-125 lb/ft in a criss-cross.
After cranking the Axle down @ 115, I thought it wise to question if that clamping force (which must be enormous) would crush my '60's 9" Housing Tube? Is the torque spec the same for front and rear?
Thanks as always.
Dawg-a-saurus
Old 04-07-2016, 10:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
9"ers are stouter than Dana 44's, IMO. The manual shows the rears same as the fronts, for F-1. What spring plates are you using in the rear? If they are just flat plates, I'd worry about them.
Old 04-08-2016, 10:41 AM
eman92082's Avatar
eman92082
Thanks Ross, Spring Plates are Gennie.
E
Old 04-14-2016, 06:32 PM
CBeav's Avatar
CBeav
CBeav is offline
I realize nobody talks about or considers this but in my line of work spring u-bolts are re-torqued every twelve months.
Old 04-14-2016, 06:41 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
So what would that line of work be? Commercial trucking?
Old 04-15-2016, 03:49 PM
filthy6's Avatar
filthy6
filthy6 is offline
I tried to look at mine to see how thick the tube wall was. Didn't have the correct measuring tool to get around all of the flanges welded on the ends. Anyone know how thick those tubes are?
Old 04-15-2016, 07:29 PM
CBeav's Avatar
CBeav
CBeav is offline
Fire engines & fire trucks, ambulances, etc. It's just become a habit to check them and only takes a minute or two. Not often, yet not uncommon to find a loose nut or two.
Old 04-15-2016, 11:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You may be able to measure it where the vent assembly screws in, if you remove the vent. My guess would be around .100".
Old 04-16-2016, 03:14 AM
Mervy49's Avatar
Mervy49
Mervy49 is offline
Occasionally you can see a truck going down the road in front of you doing what we used to call "dog tracking" usually due to a loose U bolt connection.
Old 04-16-2016, 07:27 PM
CBeav's Avatar
CBeav
CBeav is offline
More than likely the center bolt through the spring has sheared its head first then the u-bolts loosen as the axle slips back and forth over the spring.
I probably average replacing at least one set of springs each month and 4x more spring pins. We keep about ten sets of springs on hand and service around seventy trucks/engines.
Old 04-17-2016, 10:14 AM
filthy6's Avatar
filthy6
filthy6 is offline
Hard to accurately measure but visually at the vent tube it looks to be about 1/4"...could that be right?
Old 04-17-2016, 12:04 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Found this with a google search
1/4"!! I'd never have guessed it was that thick.
Old 09-14-2017, 12:02 PM
fiftford's Avatar
fiftford
fiftford is offline
Thanks!!
Hey Beav, just wanted to say thanks! Was chasing another issue on my truck and noticed my rear end was cockeyed. A quick search of the thread brought me here and sure enough, the center bolt on my drivers side spring had sheared and the rear end had shifted. Gotta love FTE and all the helpful advice on here! Thanks again
petalumaboy
Ford Truck Parts for Sale
12-08-2017 08:26 PM
'94IDITurbo7.3
25
05-14-2014 08:38 AM
REDS52F1
10-23-2013 08:40 AM
usmcBTC
06-07-2009 06:08 PM
TexasGuy001
07-05-2006 12:48 PM
Quick Reply: Quick Question - Axle U-Bolts
