Need help deciding
Old Apr 9, 2016 | 06:53 AM
  #31
Themoose56's Avatar
Themoose56
It all comes down to the previous owners care and maintenance of their truck. Most guys who own a 7.3 excursion know what they have and IMO keep up with regular maintenance on them because THEY NEVER INTEND TO SELL THEM!! But life takes unexpected turns sometimes and so maybe they need the money so they are forced to sell etc etc etc....Anyway, I also live in NJ and my search for a 7.3 EX took me up to Connecticut, is it a rusted out POS? absolutely not. Yes it has some surface rust on the frame but thats all, absolutely no body rot and the inside is so clean my buddies don't believe me when I tell them its a 2000 model year.
Clean 7.3's are out there and if you want a diesel then go buy a diesel, just do your research and know what your getting into and you'll be fine.
Old Apr 9, 2016 | 11:06 AM
  #32
USCG_PA's Avatar
USCG_PA
Originally Posted by Villero1834
ok another thing that corncers me its the diesel and cold weather factor , now i have never driven a diesel before but the main reason why i wanted an excursion was the diesel option ,here in Nj we see a lot of snow (not lately lol) so whats the deal w diesel engines and cold starts , this truck must take me to work everyday during winter so it has to start lol.
sorry for my ignorance im really trying for the diesel , the more i read about the more i like it lol
Just make sure the diesel has a block heater, or put one in if it doesn't. Then plug the block heater into a timer that will start an hour of two before you have to get up and go to work. That way your engine will be nice and warm for start up.
I will normally start plugging in when the temps are reaching below freezing.
Old Apr 9, 2016 | 12:09 PM
  #33
timf150's Avatar
timf150
Here is a nice v10 in Cali. A bit more than you may want to spend.
https://sfbay.craigslist.org/sby/cto/5515014567.html
Tim M
Old Apr 9, 2016 | 01:44 PM
  #34
Villero1834's Avatar
Villero1834
thats a nice , thanks for the find , im going to test drive a 7.3 on monday , like i said i never actually drove a diesel but im a big believer of the bigger the better lol
Old Apr 9, 2016 | 02:37 PM
  #35
Stewart_H's Avatar
Stewart_H
...im going to test drive a 7.3 on monday
Unless the rig you're gonna test drive is tuned, you'll probably be disappointed.
A bone stock 7.3L is very boring and plain jane.
Stewart
Old Apr 9, 2016 | 02:59 PM
  #36
Villero1834
damn thank for the advise , im not really interested on that particular truck but its really close to my house and i want to get the feelimg for a diesel
Old Apr 9, 2016 | 03:22 PM
  #37
Stewart_H's Avatar
Stewart_H
Honestly, even stock 6.0's are boring to me because all the 7.3's that have been in my family have always been modded and tuned.
Stewart
Old Apr 10, 2016 | 10:31 PM
  #38
lightflyer's Avatar
lightflyer
Stewart
I don't find mine to be that way.
Old Apr 10, 2016 | 11:13 PM
  #39
Stewart_H's Avatar
Stewart_H
Yeah, my bad, I should have qualified my statement and included "in my opinion..." to my post.
Stewart
Old Apr 11, 2016 | 01:12 AM
  #40
Bently_Coop's Avatar
Bently_Coop
Originally Posted by Bently_Coop
... Ensuring they are Torqued properly is the best thing. 20-25 ft lbs is recommended. ....
The Fordtechmakuloko video I posted along with several V10 members. 2000+ I believe all V10's received PI heads. Checking the casting numbers will confirm.
This guy is a former Ford technician of 10+ years
This is not the first time I have seen this higher spec value posted. Did Ford change the torque values for spark plugs and raise them?
Stewart
I have seen it a handful of times in the V10 section. Their is also a thread on here testing the strength of a factory head.
Breaking point thread:
https://www.ford-trucks.com/forums/1...ead-heads.html
Recommended Torque:
https://www.ford-trucks.com/forums/1...ed-torque.html
Old Apr 11, 2016 | 06:44 AM
  #41
harley4jcs's Avatar
harley4jcs
A lot of guys hear Hot Rod there 8000 # trucks So the stock 7.3 is really a dog when stock. (it also has GREAT upward potential)
Mine never bothered me, TILL running 35s & needing to tow. A tuner allowed for trans correction, speed-o correction & gave me the ability to pull a 18' TT downhill to the coast W/O having to push the petal through the floorboard the entire 1hr drive.
Old Apr 11, 2016 | 11:58 AM
  #42
Villero1834
News flash guys , i just test drove the 7.3 , also first time ever driving a diesel and wow , not what i was expecting at all , im looking forward to test a v10 most likely thats the truck ama end up buying , this particualr 7.3 had some good power but up on the higher rpms, when the turbo kicked in i guess. i like to travel a lot and im the kind of person that preffers a 70mph under 1500 rpm type of ride
Old Apr 11, 2016 | 12:49 PM
  #43
devovino's Avatar
devovino
Like mentioned above, as far as mustering some kind of performance from the 7.3 a good tune can/will do wonders. I bought mine allready tuned and its pretty damn quick (considering its an 8K lb wagon) and I truthfully have never driven one in stock form. Having said this, I do know that the V10 gets a lot of it pulling power high in the RPM curve so thats something to consider. Also, mine w/ 35in tires on the freeway it cruises at 71mph at 1900 rpm. I think if you rode in a reaaaly hot tuned 7.3 like Crazy Matt ownes, it would surprise the hell out of you!!!
Old Apr 11, 2016 | 12:55 PM
  #44
WE3ZS's Avatar
WE3ZS
70 MPH @ 1500 RPM isn't going to happen with a V-10, unless you mount some very tall tires on it which would decrease the performance accordingly.
Comparing RPM operating ranges between the PSD and modular motors is far from apples to apples. The V-10 has about twice the RPM operating range as a 7.3 (or 6.0), the two families of motors make their power very differently also. The PSDs make plenty of power down low with good turbo boost helping out in their upper range, the V-10 does OK at the lower range but when needed it will drop down a gear (or 2) and really get spun up where it makes it's peak power. The 6.8 is designed to operate at these higher revs and doing so isn't going to hurt them.
I run 4.88 gears with 35.28" tall tires for an effective ratio of 4.39 on my V-10 EX, it turns 2400 RPMs at 70 MPH in OD. That EX serves as our dedicated tow rig so it does that 500 to 600 miles a day when we travel with our 41' 11,000lb travel trailer hanging off the back. It does not complain at all and only drops down a gear to spool up a bit higher on the steeper hills, it does get thirsty but otherwise no issues at that RPM for prolonged runs under load.
Old Apr 11, 2016 | 11:45 PM
  #45
Villero1834
So kind of like i should give the 7.3 another try?
