Hydra
Old Apr 2, 2016 | 02:16 PM
  #46
Joe28443's Avatar
Joe28443
Joe28443
I've got the calibration, my computer will not allow me to send it. Still trying to figure out something
Old Apr 2, 2016 | 07:46 PM
  #47
cleatus12r's Avatar
cleatus12r
Butt-Head
Rename it something other than ".bin". Some email servers don't like ".e x e" or ".bin" files because of virus or corruption problems. ".jpg" works.
Old Apr 2, 2016 | 08:13 PM
  #48
Joe28443's Avatar
Joe28443
Joe28443
I saved it as a bin file, I will try and save it as something else
Old Apr 4, 2016 | 10:42 AM
  #49
Joe28443's Avatar
Joe28443
Joe28443
This is what the connections look like, are the copper ones cleaned too much ?
Old Apr 4, 2016 | 10:54 AM
  #50
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
The ones with the copper showing might be worn down a bit much. What I did was get a magnifying glass and a wooden tooth pick and scrape off the gel coating. I then wiped it with rubbing alcohol to get a final good cleaning. If I had not been using the magnifying glass, I would have left a lot of residue on the pins.
Make sure you are cleaning both sides of the contacts.
Old Apr 4, 2016 | 11:08 AM
  #51
Joe28443's Avatar
Joe28443
Joe28443
I figured the copper should not be showing, however my DP tuner chip works fine, it's the hydra I am having a problem with. I was curious if this was the problem
Old Apr 4, 2016 | 11:36 AM
  #52
Joe28443's Avatar
Joe28443
Joe28443
I finally hooked it back up and it will run now but the theft light is still on, can anyone take a pic of where hat plug is that I need to unplug. I unplugged one but that did not do it
Old Apr 4, 2016 | 12:01 PM
  #53
Joe28443's Avatar
Joe28443
Joe28443
Theft light stayed on a minute and has now gone off. Who knows, I guess I can live with it tho
Old Apr 4, 2016 | 01:52 PM
  #54
cleatus12r's Avatar
cleatus12r
Butt-Head
Did you ever try this :
THEFT*LIGHT (on Excursions) - If the theft light flashes rapidly and the vehicle won't start, the Passive Anti-theft system (PATS) will need to be reset. To reset the*PATS, perform the following steps:
Turn the key on, but do not attempt to start the vehicle.Wait for the theft light to quit flashing rapidly. This should take about 45 seconds, after which the THEFT light will flash multiple times about every 3 seconds.Turn the key off and remove the key from the ignition for 30 seconds.Insert the key and turn the ignition to the ON position.The THEFT light should illuminate for about 5 seconds and then go out.PATS*System should now be resetYou should be able to start your vehicle normally.
Old Apr 4, 2016 | 01:59 PM
  #55
cleatus12r's Avatar
cleatus12r
Butt-Head
The THEFT light cannot physically illuminate if the correct module was unplugged.
Old Apr 4, 2016 | 02:28 PM
  #56
Joe28443's Avatar
Joe28443
Joe28443
I did not pull he correct module apparently. Is it this one?
Old Apr 4, 2016 | 03:03 PM
  #57
ExPACamper's Avatar
ExPACamper
That white plug...right under the steering column and to the right? Looks like the Baro sensor, doesn't it?
Old Apr 4, 2016 | 06:17 PM
  #58
cleatus12r's Avatar
cleatus12r
Butt-Head
The green one behind it....like I said earlier in the thread in post #2.
Old Apr 8, 2016 | 04:45 PM
  #59
Twila Dixon Snider's Avatar
Twila Dixon Snider
Smile Anti- theft stays OFF
I have a 2004 F250 6.0. The Anti-Theft light never blinks. The truck starts and runs. Just looking for some answers. Thanks Twila
Old Apr 8, 2016 | 05:07 PM
  #60
Joe28443's Avatar
Joe28443
Joe28443
What kind of answers? If your theft light does not blink and it runs you are good
