Hydra
Old Mar 30, 2016 | 10:12 AM
Joe28443's Avatar
Joe28443
Joe28443
Hydra
Anybody got a hydra in an excursion? Do you have a flashing theft light? I spoke with php over email and they said there is no way of getting it to stop. But you can drive it that way! What am I supposed to do put some duct tape on my dash?
Old Mar 30, 2016 | 10:49 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Above the accelerator pedal there is a small module with a four-wire connector (green or red in color). Unplug that and your light won't flash.
However, there should be an option in the Hydraflash software that allows you to enable PATSin the calibration.
Old Mar 30, 2016 | 11:34 AM
Joe28443's Avatar
Joe28443
Joe28443
There is an option, and I had it enabled on all my calibrations. It's still flashing. php said there is no way of stopping it
Old Mar 30, 2016 | 11:56 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Unplug the module under the dash then.
Old Mar 30, 2016 | 02:59 PM
Joe28443's Avatar
Joe28443
Joe28443
Check engine light is on as well. I'm not riding around all half ***, I will put my DP back in. I removed all programs and reinstalled them and it still is doing it
Old Mar 31, 2016 | 10:17 AM
Joe28443's Avatar
Joe28443
Joe28443
If hydra can accept tunes from different vendors, could I get a tune from someone other than php to email me one to try it and see if that fixes my problem?
Old Mar 31, 2016 | 10:23 AM
HKusp's Avatar
HKusp
It does, there are several vendors that support Hydra, or vice versa depending on which way you look at it. Tony Wildman and Gearhead are 2 of the best/most popular.
Old Mar 31, 2016 | 11:48 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
What hex code are you using? And what is your current PCM hex code or box code?
Old Mar 31, 2016 | 11:51 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
If you have the optional USB cable, you can use it to read the current PCM calibration. If you email me the calibration I can put the PATS information in your current file and send you a new one.
Old Mar 31, 2016 | 01:31 PM
Joe28443's Avatar
Joe28443
Joe28443
I have the usb cable, how do I get what I need
Old Mar 31, 2016 | 01:32 PM
Joe28443's Avatar
Joe28443
Joe28443
Like the VRAA6Y3?
Old Mar 31, 2016 | 01:37 PM
Joe28443's Avatar
Joe28443
Joe28443
It's a box code of EBM1 which by there decoder that's a VRAA6Y3
Old Mar 31, 2016 | 03:05 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Connect your laptop to the USB cable with the chip attached to the PCM. Turn on the ignition and select the "read pcm" (or similar ) option from the Hydraflash menu.
Old Mar 31, 2016 | 03:21 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
... And yes, VRAA6Y3 is the correct PCM code for your Excursion.
Old Mar 31, 2016 | 03:38 PM
Joe28443's Avatar
Joe28443
Joe28443
Do I still need to do that if that's my correct calibration ?
