Ford Sync wont update
Old May 16, 2016 | 10:27 AM
  #106
JeepPuller's Avatar
JeepPuller
Originally Posted by FordIVTteam
Hi Everyone,
If you open the original download and see anything other than a SYNCmyride folder (with several zipped files inside), autoinstall.lst, and install.lst listed then, the files are not going to copy properly in order for the update to install. If you are using a Mac, right click on the downloaded file, and choose to open with Stuffit Expander. SYNCmyride should not show as an attachment to any cab files, and autoinstall, and install should be listed outside of the SYNCmyride folder. If you are using a Windows PC, you must choose to extract those 3 items directly from the download and choose the flashdrive as the destination point. For anyone who has attempted this, please delete the files from the computer and redownload the update to try again. The files’ names may differ because they are VIN specific, but the 3 that I mentioned, will all be listed the same and that it is all that you need on the USB. You should not have to make any alterations to the files, folder, or names of the files. If you have a case open, I suggest that you try this as well.
Joy
Hello Joy,
I followed your instructions to re-download the file today.
This DID NOT work either.
Please advise.
Old May 16, 2016 | 11:03 AM
  #107
FordIVTteam's Avatar
FordIVTteam
Official Ford Rep
Originally Posted by rmeaux
Using Stuffit does output the files without the folder directory attached to them.
IMHO - if this method is required to do it properly I believe the instructions should be updated which currently show via images and text instructions having OS X handle the .zip extraction. With no mention of third party software.
I can recall at least the last four years of OS X releases, that it has auto handled .zip files and extracted them and placed the .zip file in the trash. Which is still recoverable and usable.
This would have save me about 3 hours of investigation Saturday if this works.
I am not near the vehicle at the moment, but I have made the USB drive using this method and will post an update around 6:00 pm CST 05/16.2016.
I still do Thank you for your help Joy (I also see a Cara on here) as I know you are only one person and there are many that make these updates come to fruition.
rmeaux,
You're welcome. I am looking forward to reading your post!
Originally Posted by JeepPuller
Hello Joy,
Please advise.
Hi JeepPuller,
Are you having an issue seeing the correct files or do you have the files correctly, but you still receive an error when trying to install them?
Joy
Old May 16, 2016 | 11:14 AM
  #108
JeepPuller's Avatar
JeepPuller
Hi JeepPuller,
Joy
I am working from a PC. I see the correct files.
I still receive an error when trying to install them.
Old May 16, 2016 | 11:27 AM
  #109
FordIVTteam
Official Ford Rep
JeepPuller,
What options are you selecting to start the update on SYNC? Which SYNC system is your truck equipped with? SYNC Help & Vehicle How To's | Official Ford Owner Site
Joy
Old May 16, 2016 | 11:53 AM
  #110
JeepPuller's Avatar
JeepPuller
JeepPuller,
Joy
I have Basic Sync.
I select USB, System Settings, Advanced, Install Application, Install...
There should be a 'record' of this information with the following case number:
You're welcome! I submitted your case and the case number for reference is CAS-9458327. A team member will contact you once a resolution has been made.
Cara
Old May 16, 2016 | 01:24 PM
  #111
FordIVTteam
Official Ford Rep
I have Basic Sync.
Hi JeepPuller,
I have reviewed your case (CAS-9458327) and the issue with installing the SYNC update is still being investigated by our engineers. Once a solution is determined, a supervisor will email you directly on how to receive a successful update to install.
I hope that we can get everything resolved quickly for you!
Barb
Old May 16, 2016 | 01:31 PM
  #112
catisland's Avatar
catisland
I have downloaded and attempted installation of the sync update. The problem I am having is after an hour of installation and numerous "installation complete" messages. It still says Radio and Media are unavailable. Did I screw something up????
Old May 16, 2016 | 01:39 PM
  #113
JeepPuller's Avatar
JeepPuller
Hi JeepPuller,
Barb
Thank you Barb.
I will wait to be contacted.
Old May 16, 2016 | 02:12 PM
  #114
catisland's Avatar
catisland
Update to my previous post: Pulled the jump drive out and restarted my truck, everything works fine now, but failed to update. Guess I am not going to attempt to update!
Old May 16, 2016 | 03:08 PM
  #115
FordIVTteam
Official Ford Rep
Thank you Barb.
You're quite welcome, JeepPuller!
Hi catisland,
I'm glad to hear your system is working now. As for the update, use the Version Checker Tool available here to see if the software finished installing to SYNC: https://owner.ford.com/tools/account....html#/prepare
Let me know if you have any questions!
Barb
Old May 16, 2016 | 06:02 PM
  #116
rmeaux's Avatar
rmeaux
Happy Happy.
Installed right away. Got the install complete message after about 10 minutes. Looked like it was stalled. Re-synced my phone via Bluetooth and it jump started everything.
I now see media info while connected via Bluetooth. Yay.
Joy, Cara, and Barb. Please request that Ford highly suggest the use of Stuffit in the instructions. This would reduce our headache as well as yours I'm sure. First time I had to use third party decompressing software in a long long time.
Cheers.
Old May 16, 2016 | 07:36 PM
  #117
William E Meader's Avatar
William E Meader
Sync File not found
I have a 2010 ford have tried to install the updates getting same result files not found have read through all these threads and have tried pretty much everything everyone has suggested still won't work very frustrated
Old May 17, 2016 | 07:50 AM
  #118
FordIVTteam
Official Ford Rep
Happy Happy.
Cheers.
rmeaux,
Happy to hear you're back up and running! I'll be sure to pass on your concern. Let us know if you need our assistance again
William E Meader,
Are you installing the 4.4 or 4.6 update?
Cara
Old May 17, 2016 | 11:05 AM
  #119
dh_meyer's Avatar
dh_meyer
Do the file names mentioned in the install text files match the file names in the directory ?
Old May 17, 2016 | 04:06 PM
  #120
LoveMy2010Lariat's Avatar
LoveMy2010Lariat
Will someone help me troubleshoot my Sync upgrade issue? I have run out of things to try and Rodeo Ford wants to charge me $80 to do the upgrade for me. I'm not opposed to paying if I have to but would rather try a bit harder and see what the community says first.
This is my first Ford and my first truck. Loving it except this upgrade issue. I called the 800 number listed in the radio contacts to try and get it resolved; however, I wasn't able to get very far before they said go to any dealer to get it fixed.
VEHICLE: 2010 F150 Lariat SuperCrew (44k miles out of warranty)
CURRENT SYNC VERSION: Gen1 - V3.1
AVAILABLE VERSION: Sync 4.4 (DE8T-14D544-AC.zip)
Here is what I do to recreate the issue.
1. Formatted the 8GB Toshiba with FAT32 (Non-Quick format)
2. Downloaded DE8T-14D544-AC.zip to my Windows Desktop
3. Extracted Files in .zip to the 8GB Toshiba USB thumb drive's Root Folder (My E:\)
4. Verified the following files are visible.
E:\SyncMyRide (5/17/2016)
E:\SyncMyRide\8L2T-14D546-AF.cab (4/16/2016 108KB)
E:\SyncMyRide\DE8T-14D544-AC.sec (4/16/2016 109,230KB)
E:\SyncMyRide\E1BT-14D546-AA.cab (4/16/2016 18KB)
E:\SyncMyRide\E1BT-14D546-BB.cab (4/16/2016 124KB)
E:\SyncMyRide\E1BT-14D546-CA.cab (4/16/2016 72KB)
E:\SyncMyRide\E1BT-14D546-FB.cab (4/16/2016 18KB)
E:\SyncMyRide\E1BT-14D546-GA.cab (4/16/2016 238KB)
E:\SyncMyRide\E1BT-14D546-HC.CAB (4/16/2016 101KB)
E:\SyncMyRide\FJ5T-14D546-AAA.pks (4/16/2016 29KB)
E:\autoinstall.lst (4/16/2016 1KB)
E:\install.lst (4/16/2016 2KB)
5. Safely Eject the Toshiba USB from the PC
6. Turn on Car (Engine Running)
7. Plug in USB
8. Press Media Hard Button on Radio and select user device USB
9. Press Settings
10. Press Install
11. Briefly see "Beginning Installation"
12. See 'File Not Found' Error on screen and hear female sync voice saying Install file not found, be sure usb is correctly plugged, etc.
Things I have tried.
1. Opened install.lst on usb thumb drive file using Notepad app on PC and verified Contents
; USB Update Application !
; USB Installation !
; Microsoft Windows Automotive !
[Windows Mobile For Automotive 5.8]
Item1 = 8L2T-14D546-AF
Open1 = SyncMyRide\8L2T-14D546-AF.cab
Item2 = E1BT-14D546-CA
Open2 = SyncMyRide\E1BT-14D546-CA.cab
Item3 = E1BT-14D546-GA
Open3 = SyncMyRide\E1BT-14D546-GA.cab
Item4 = FJ5T-14D546-AAA
Open4 = SyncMyRide\FJ5T-14D546-AAA.pks
Item5 = E1BT-14D546-FB
Open5 = SyncMyRide\E1BT-14D546-FB.cab
Item6 = E1BT-14D546-BB
Open6 = SyncMyRide\E1BT-14D546-BB.cab
Item7 = E1BT-14D546-AA
Open7 = SyncMyRide\E1BT-14D546-AA.cab
3. Reviewed all files match the file name and case sensitivity in SyncMyRide, they didn't so I changed them to match, still failed
4. Opened autoinstall.lst and reviewed all files match the file name and case sensitivity in SyncMyRide, etc
5. Tried without autoinstall.lst and tried without install.lst each failed.
6. Tried 2 or 3 other brand USB drives and experienced fails.
7. Tried factory resetting the radio.
My thought is that it has something to do with jumping from Gen1 3.1 to Sync4.4. I would like to find a version in between these versions to see what happens during install. My guess is that I could go to Gen1 3.1 to Gen1 3.2+ without any issues.
Any other thoughts on what might be causing the file not found issue?
