Ford Sync wont update
Old May 11, 2016 | 09:52 AM
  #91
FordIVTteam's Avatar
FordIVTteam
Official Ford Rep
Originally Posted by JeepPuller
These steps also failed. I sent you a PM with my VIN.
Numerous attempts, all with different USB sticks. Please help.
JeepPuller,
Check out your PM
Originally Posted by wrvond
I'm not positive, because it's been several months, but I think I had to put all the extracted files on the usb outside of their folders...
wrvond,
Are you updating to 4.4 or 4.6?
Cara
Old May 11, 2016 | 12:27 PM
  #92
wrvond's Avatar
wrvond
Originally Posted by FordIVTteam
wrvond,
Cara
Hi Cara,
I updated to 4.4 January of 2016.
I have checked online, and it says I am up to date with 4.4, yet I'm hearing that there is a 4.6 available.
Is there another source for updates, or does it take time to become available to everyone through the website?
Old May 11, 2016 | 01:43 PM
  #93
FordIVTteam
Official Ford Rep
Hi Cara,
wrvond,
Each update is vehicle specific, so I recommend keeping an eye on your account for the availability.
Cara
Old May 12, 2016 | 12:20 PM
  #94
bouttime's Avatar
bouttime
When I download to my mac I don not get a .zip file nor do I get the 2 install files with the rest in a folder they are all separate. When trying to install the directions are not even close but when I do get there it says install file not found or something to that effect.
Jeff
Old May 12, 2016 | 01:21 PM
  #95
FordIVTteam
Official Ford Rep
Hi Jeff,
Can you try opening the download with Stuffit Expander? That should give you the proper list and format of the files.
Joy
Old May 12, 2016 | 01:36 PM
  #96
bouttime's Avatar
bouttime
Joy,
That doesn't work. As soon as I click on the folder in my downloads folder it shows all the individual files.
Jeff
Old May 12, 2016 | 02:56 PM
  #97
FordIVTteam
Official Ford Rep
Originally Posted by bouttime
Joy,
Jeff
Hey Jeff,
Can you send the VIN in a PM?
Cara
Old May 15, 2016 | 09:56 AM
  #98
rmeaux's Avatar
rmeaux
Joy,
Jeff
Macs/Apples automatically unZip and extract .zip files to the respective down;had folder and trash the original. It is a normal process.
However, it does nothing to fix the issues with updating your vehicle. I am having trouble too.
Old May 16, 2016 | 08:17 AM
  #99
FordIVTteam
Official Ford Rep
Hi rmeaux,
Are you having trouble installing the update with the correct files or are you also experiencing a problem with getting the proper items on to the USB?
Joy
Old May 16, 2016 | 08:35 AM
  #100
JeepPuller's Avatar
JeepPuller
I took at look at the install and autoinstall files...
The install.lst file makes reference to what appear to be codes that relate to the .cab files in the SynchMyRide directory.
I also notice that 'my' code (from synchmyride.com) is AR3T-14D544-AE, and this code is not present in the install.lst file or the sub-directory.
The file autoinstall.lst contains similar references except the .cab file line makes no reference to the SyncMyRide directory; thusly looking in the 'root' directory where there is NOTHING.
All this has me wondering if this update is 'tweaked' every time some reports failure, and this tweak involves adding the missing .cab file for the particular individuals 'code'.
This may be why our VIN is requested, so they can look up the original code and add what is missing.
I may be wildly off base here; not knowing the details of how Ford codes these updates makes this a SWAG.
Anyone care to weigh in on how long it takes to get resolution once a case has been created? I would like to update synch in my truck.
Old May 16, 2016 | 08:37 AM
  #101
rmeaux's Avatar
rmeaux
Hi rmeaux,
Joy
I can get the files on the USB fine. I have done that using every scenario possible.
I have done a full format of any drive I've used.
I tried:
- having the files in the SyncMyRide folder and the install file separate just like the images in the instructions show.
- I've tried having all files in the root of the drive.
- I've tried having a copy of each file with and without the folder name in the the filename.
- /SyncMyRide/filename.nnn
- filename.nnn
- I've tried the above scenario with the files in and out of a SyncMyRide folder. At one time, both places at the same time.
- I've also tried with and without the autorun file in and out of the folder.
- I've tried other favors of mix and match of the above scenarios.
No matter what, still get a files not found on touchscreen.
Also performed a Master Reset on head unit.
Old May 16, 2016 | 08:45 AM
  #102
rmeaux's Avatar
rmeaux
I've dug in these files too using TextWrangler and tried to stare and compare at what was suppose to happen when executed.
I too noticed the filenames as having the folder directory in them and then not.
Like I said in my last post. I made a copy of each file and removed said folder path. Left both copies on the drive, in a folder and in root at the same time. The install file still can't locate them.
I also tried removing all unnecessary text and comments from the top of the install and autorun file. No changes. Good or bad.
Trying to update a 2012 Expi EL Limited before a trip and it's frustrating.
Wanted to update before my last trip because my current version shows no media info while using Bluetooth. But there was nothing to download at that time. Not even an older or current version.
Old May 16, 2016 | 08:49 AM
  #103
JeepPuller's Avatar
JeepPuller
Thanks for doing this and updating the thread; I was planning the same approach, but now feel it will be a waste of time.
I sure hope we get some resolution soon; I doubt we will ever know what is changed if/when it works.
Old May 16, 2016 | 10:01 AM
  #104
FordIVTteam
Official Ford Rep
Hi Everyone,
If you open the original download and see anything other than a SYNCmyride folder (with several zipped files inside), autoinstall.lst, and install.lst listed then, the files are not going to copy properly in order for the update to install. If you are using a Mac, right click on the downloaded file, and choose to open with Stuffit Expander. SYNCmyride should not show as an attachment to any cab files, and autoinstall, and install should be listed outside of the SYNCmyride folder. If you are using a Windows PC, you must choose to extract those 3 items directly from the download and choose the flashdrive as the destination point. For anyone who has attempted this, please delete the files from the computer and redownload the update to try again. The files’ names may differ because they are VIN specific, but the 3 that I mentioned, will all be listed the same and that it is all that you need on the USB. You should not have to make any alterations to the files, folder, or names of the files. If you have a case open, I suggest that you try this as well.
Joy
Old May 16, 2016 | 10:26 AM
  #105
rmeaux's Avatar
rmeaux
Using Stuffit does output the files without the folder directory attached to them.
IMHO - if this method is required to do it properly I believe the instructions should be updated which currently show via images and text instructions having OS X handle the .zip extraction. With no mention of third party software.
I can recall at least the last four years of OS X releases, that it has auto handled .zip files and extracted them and placed the .zip file in the trash. Which is still recoverable and usable.
This would have save me about 3 hours of investigation Saturday if this works.
I am not near the vehicle at the moment, but I have made the USB drive using this method and will post an update around 6:00 pm CST 05/16.2016.
I still do Thank you for your help Joy (I also see a Cara on here) as I know you are only one person and there are many that make these updates come to fruition.
