Ford Sync wont update
Old Apr 7, 2016 | 05:58 PM
  #31
ryoken31's Avatar
ryoken31
Originally Posted by FordIVTteam
Hi ryoken31,
Please send your VIN in a PM. I'll get more information for you.
I need one more post for PM privileges. I've been a member of this forum since I bought my 2003 F-150 back in 2008 but mostly a lurker. Hopefully the moderators don't deem this as against the rules. If so I'll go find another thread to add some useful information to.. Hopefully have the VIN to you shortly!
Old Apr 8, 2016 | 10:32 AM
  #32
FordIVTteam's Avatar
FordIVTteam
Official Ford Rep
[QUOTE=elite64a;16188928]
Originally Posted by elite64a
Are you using an Apple or Windows computer?
I initially tried a windows computer since sync was designed by Microsoft. During my first two attempts I used google chrome as a browser then IE. When that didn't work I tried an apple computer using Firefox as the browser then tried safari. None of these worked.
Is the USB formatted to FAT32, and are the files and folder on the root directory of the USB drive?
No worries. I'll see if I can send you a PM first.
Originally Posted by cdmm151
I did try a master reset with tech services helping. No change.
If you're still experiencing those issues after a master reset, you will need to go to the dealer.
Keep me posted.
Shaay
Old Apr 8, 2016 | 11:01 AM
  #33
elite64a's Avatar
elite64a
[QUOTE=FordIVTteam;16190886][QUOTE=elite64a;16188928]
Yes the USB is formatted to FAT32 and all the files are in the root directory of the USB drive. I followed all the posted instructions from syncmyride to the letter.
I am not sure if it matters or not but the sync system I am working with has not been updated since it was installed at the factory. Like previously stated I was told by tech support that there are issues with this update; my experience thus far with sync is that is true. I hope things get worked out soon.
Old Apr 8, 2016 | 01:26 PM
  #34
FordIVTteam
Official Ford Rep
elite64a,
If you've never updated since the beginning, it's quite possible that the version is too far behind for you to perform the update on your own. Can you check the CCPU version in the vehicle using the following instructions:
1. Press the GEARS icon at the bottom of the screen.
2. Select HELP on the left.
3. Select SYSTEM INFORMATION in the middle.
4. You should see the CCPU listed there.
Shaay
Old Apr 8, 2016 | 04:17 PM
  #35
elite64a's Avatar
elite64a
elite64a,
Shaay
Ok I could not find what you were asking by using your instructions but I did pull the system information which is what you were asking I assume. There were no gears anywhere in my system. Anyway here is what I was able to see in my system information page
Auto Version Number:
EAO42_5.8.08351_spO.
FPN Number:
BG1T-14D544-AB
I do appreciate you trying to help me out here.
Old Apr 9, 2016 | 08:29 AM
  #36
FordIVTteam
Official Ford Rep
FPN Number:
BG1T-14D544-AB
Previously, you mentioned that you have the 8" touchscreen which is known as the MyFord Touch. According to your FPN, sounds like you may have SYNC with Voice-Activated Navigation instead. Please send your VIN in a private message. I'd like to provide the proper instructions for your vehicle.
Shaay
Old Apr 9, 2016 | 02:09 PM
  #37
Tech740's Avatar
Tech740
My 2011 with basic sync won't update either I have tried multiple formatting and downloads. Just says the installation file isn't there. It clearly is.
Old Apr 9, 2016 | 03:02 PM
  #38
dh_meyer's Avatar
dh_meyer
elite64a,
Shaay
Does the "you have too old of a version to upgrade on your own" apply to those of us with the 'basic Sync' version ?
Since the web site knows which version we have, shouldn't it, tell me
this and prevent the download attempt ? Or better yet, customize the download based on the version I have ?
Old Apr 9, 2016 | 03:38 PM
  #39
FordIVTteam
Official Ford Rep
Hi Tech740m,
Please send your VIN in a private message, and we'll go from there.
This is not the case. Also, we've discovered that elite64a is also trying to update to version 4.4. The issue with this update is still ongoing. Our engineers are working to get it corrected, but there is not an ETA at this time. I sent you a message; check it out.
Shaay
Old Apr 21, 2016 | 09:16 PM
  #40
HDBiker67's Avatar
HDBiker67
having the same exact issues.
I did a Vehicle health report, downloaded the files to a USB drive, there are no other files or folders on it, it wont update.
I thought about just going to the dealer to have them do it, but seems they might have the same issues.
Old Apr 23, 2016 | 10:39 AM
  #41
FordIVTteam
Official Ford Rep
Hi HDBiker67,
I don't recommend going to the dealer, because this is a known and ongoing issue. If you want to be contacted once the issue is resolved, send your VIN in a private message.
Shaay
Old Apr 23, 2016 | 12:04 PM
  #42
HDBiker67's Avatar
HDBiker67
Hi HDBiker67,
Shaay
Thanks Shaay. Will do.
Old Apr 23, 2016 | 01:46 PM
  #43
FordIVTteam
Official Ford Rep
You're welcome, HDBiker67.
Shaay
Old Apr 23, 2016 | 08:01 PM
  #44
Curtwhite's Avatar
Curtwhite
Can you send me the instructions also for the SYNC with Voice-Activated Navigation? I'm having the same issue with the same system as elite64a. The Ford website is no help.
Old Apr 25, 2016 | 02:06 PM
  #45
FordIVTteam
Official Ford Rep
Hi Curtwhite,
Here are the instructions for installing updates:
1. Press the PHONE button on the radio.
2. Select SETTINGS.
3. Select ADVANCED.
4. Scroll down and select INSTALL APPLICATION.
However, there is an ongoing issue with version 4.4. Send the VIN in a private message if you're unable to install.
Shaay
