Sponsored by: Auxito
Auto climate control
Old Mar 27, 2016 | 07:55 AM
racin's Avatar
racin
Can a manual climate control unit be replaced with the digital one or are the hook up different?
Old Mar 27, 2016 | 07:55 PM
kd4gij's Avatar
kd4gij
It is not plug and play. The plug is different and there is sensors that you don't have.
Old Mar 27, 2016 | 10:10 PM
blupupher's Avatar
blupupher
It can be done, but it is a lot of work. You need to remove the dash, sensors that need to be added, different vacuum lines than need to be run. Seems I had read of someone trying and they gave up.
Old May 20, 2016 | 09:14 PM
Travis S's Avatar
Travis S
That someone wasn't a RX7 owner, that's for sure. We have more determination than that. Looks like I'll be the first to pull off this trick. So in this thread, I'll be documenting the whole conversion.
Grabbed the Logicon (Logic Controller, aka control box) today along with a one-button trip computer & compass/mirror setup from a 01 Expedition. Bit of advice: Be incredibly careful when removing the mirror or this picture will happen. Sliced my finger open when it suddenly came loose, taking a piece of windshield with it. Fortunately, the good folks at PickNPull doctored me up for free.
Anyway, the 01 donor truck was missing the sun sensor & inside air temp sensors, so I got the pigtails for them while there. It was the only one with the digital logic on I could find (they are all the same). But the sensors are pretty common tho. I'll report back with part numbers later.
You WILL need the blend door actuator (5 wires) & blower motor controller from the donor truck. They are different from the analog version. I didn't have enough time to extract them, due to getting an engine for a friend and not coming properly equipped or educated enough. Next time Gadget, next time...
While at another salvage yard, I spotted a 98 Expedition which has the two-button trip computer. Next time I'm there, I'll grab it too. Another 98 Expedition with sunroof had the two-button mini console trip computer too.
97-98: two button trip computer/compass
99+: one button trip computer/compass
Old May 27, 2016 | 10:28 PM
Travis S's Avatar
Travis S
Okay, a small but extremely useful update. I want to mention that ALL DIGITAL LOGICONS for 97-02 are the same.
Today I went back to the junkyard and resumed progress on the Logic one's donor truck, a 99 Expedition Eddie Bauer edition. Someone pre-pulled the fully optioned overhead console with 2 button trip computer (00+ base models are 1button) so I grabbed it in exchange for the DOA one I got last time. 2 hours later, I have the dash spun aside and removed the Inside Air Temp sensor (with duct line), Blower Motor Controller, compass sensor, and the blend door actuator, all with undamaged wiring pigtails attached. Please note that I was not very careful and ended up removing the actuator as Jeremy Clarkson would (Hammer time). I do not condone destroying a heater box, but I was on an expedited timetable due to my cat getting heat stroke.
Overhead Console trip computer booted right up on the first try, showing "98 miles to empty". Details on part numbers for cross-referencing will follow tomorrow morning when I get a chance to get pictures uploaded
Old May 27, 2016 | 10:59 PM
blupupher's Avatar
blupupher
I would love to have a miles to empty. Stupid that the King Ranch that has all the options does not have that.
Old May 28, 2016 | 01:21 PM
Travis S's Avatar
Travis S
As promised, here's the bit of awesomeness I hinted at earlier...
PART NUMBER INFORMATION:
Location
Part#
Ford Pigtail #
MotorCraft Pigtail#
Airtex/Wells/ BWD/ Standard Pigtail
C2008 Sun Load Sensor
(Top of dash, center)
F6XZ-19E663-AB
3U2J-14B475-EHA, 3U2Z-14S411-EHA
WPT-314
Airtex/Wells 1P1810
C297 Cabin Air Temp. Sensor
F85H-19C734
BWD# PT1611
Standard# S1835
C196 Ambient Temp Sensor*
F87Z-12647-AA,
F87Z-12A647-AA,
Standard# TX12,
Dorman# 902021
3U2J-14B475-LVA, 3U2Z-14S411-LVA
WPT-437
Standard# S612, Airtex/Wells 1P1095
C229 Heater Blend Door Actuator
XL3Z-19E616-AB,
Dorman# 604216
XL3H-19E616-AA
1W3Z-14S411-AB
WPT-100
Standard# S-1775, Airtex/Wells 1P2186
C282 Blower Motor Speed Controller #1 (5pin Green)
F5LF-19E624-AC
Y17Z-19E624-AA,
YL7Z-19E624-AA
Motorcraft# YH1837, Standard# RU1231 or RU538
3U2Z-14S411-UEA (5pin)
WPT-566
Standard# S-1788
C205 Blower Motor Speed Controller #2 (2pin Yellow)
3U2Z-14S411-ZHA (2pin)
WPT-727
Airtex/wells 1P1757, 1125
C445 Compass Sensor
97-98: F75z, 99 is XL1F, 00+ is YL1F/4L2Z
F75Z 19A548-AA
4L2Z 19A548-AA
XL1F-19A548-AE
3U2Z-14S411-DA
WPT-234
Standard# S-2196
Airtex/Wells# 1P1777, 1145
C928 Trip Computer Display
XL1F-10D898-BC
(99 2-button)
I could not easily identify the C928 trip computer connector offhand, but it is basically a 20-pin version of the Heater Blend Door Actuator connector (8 pins, 5 in use). I know I've seen this style before somewhere, just can't place it offhand to pin down a part number, source or manufacturer. Delphi Micropack maybe?
Here's a picture of it:
Also, I want to mention that the Ambient Temperature Sensor cross-references to a TON of different numbers. This list is not all-inclusive (it lacks the Hyundai/Kia info for 00-06 XG350/Optima/Sonata) but will help one well in the junkyard:
Delphi# 213756
Nissan# 250680B010 & 250680B0100
GM# 25174199
Ford# D84Y12A648A, DY265, DY303, DY464, DY650, DY675, DY681, DY718, E0AE12A648AA, E1AF12A648AA, E4AF12A648A, E4AF12A648AA, E4AZ12A648A, E6DF12A648AA, E6DZ12A648, E6DZ12A648A, E6DZ19E702A, E8OY19E702A, F0AZ19E702A, F0VY19E702A, F1AF12A648AA, F1AF12A648BA, F1AF12A697BA, F1VY19E702A, F2AF12A648AA, F2AZ19E702A, F2VF12A648AA, F2VY12A646A, F2VY12A648A, F3VF12A647AA, F3VY12A647A, F3VY12A648A, F3XA12A648AA, F3XY12A648A, F5OY19E702A, F6XZ19E702AB, TX45, XF5219E702AA, XF5Z19E702AA
Airtex/Wells# 5S1141 & 5S1143
Standard Brand# TX12
MasterPro# 29382
Old Jun 10, 2016 | 05:51 PM
Travis S's Avatar
Travis S
So I began wiring both the climate control system and overhead console today. With regard to one splice I made, I will simply say this:
This is hell.
To wire the overhead console, you have to tap into Pin 43 at the PCM. As my truck was NOT wired for the console, I opted to tap it directly at the PCM. Battery tray comes out, PCM unplugged (10mm socket needed) and harness de-taped. This majorly sucked to do, but I was able to cut and splice it successfully. Ran it out to a 2-pin Metripack connector to make the rest of the run easier.
Hopped back inside, disassembled the dashboard and spliced into the VSS and Fuel level signal behind the cluster and Backlight right off of the Main Light Switch, running all of them to a 10-pin Metripack connector stashed beside the steering column. Also got the ground from the kick panel lower ground bolt (I think G200?, someone correct me on this). Next comes the AWD Low signal from the transfer case (beside the gauge cluster) and running everything up the A-pillar tomorrow
When I get my phone fixed (flex cable failing) next week, I'll get pictures of everything. But for this weekend, wiring shall continue.
Old Jun 20, 2016 | 02:55 PM
KD4PWH's Avatar
KD4PWH
Thanks for the part numbers. Kudos for undertaking this project! I look forward to seeing completion. Keep posting updates please!
Old Jun 20, 2016 | 07:56 PM
Travis S's Avatar
Travis S
Glad I could help. Since my last post, I finished the install by tapping into the AWD Relays. My truck (December 1996/January 1997 build) did not have the correct pin on the AWD Relay connector, so I mistakenly tapped into its ground. Made no visible difference, so I strung the wires through the dashboard, up the A-pillar and above the headliner to another 10-pin Metripack connector. There, a short subharness plugs in and connects to the trip computer.
I apologize for the lack of pictures, the replacement flex cable for my phone was DOA, so I bought a parts phone to transplant the upper half from as soon as my friend Matt gets back this weekend. Pics will follow then.
Old Jun 20, 2016 | 08:02 PM
TruckinAL's Avatar
TruckinAL
Wow climate control Hummmmm I don't think I would touch that with a ten foot pole . Without a donor vehicle that it was known to work before it's demise
Old Jun 22, 2016 | 05:30 PM
Travis S's Avatar
Travis S
Fortunately, wiring is my specialty and I'll be making a retrofit kit. Doing the overhead console retrofit wasn't too hard, just a bit annoying to string wiring through the dashboard. The hardest part of the climate control conversion will be replacing the blend door motor with the digital version. Same process as replacing it stock for stock, just a PITA to pull the dashboard.
shadowdd
Dec 10, 2007 02:57 PM
GrassHopper2
Jan 26, 2006 07:09 PM
xp8103
Nov 13, 2005 03:26 PM
UKSuperduty
Jun 17, 2005 09:41 AM
jmac2725
Jan 30, 2005 02:27 PM
