AC question
Edit-- When you did this test, was the high pressure switch plugged in? You may want to jumper both the high side along with the low side, and see if the compressor clutch will click.
If the AC does in fact need a charge, that means there is a leak somewhere which would need to be fixed. However, if the system needs a charge or is empty, I'd take out the orifice tube and inspect/replace it (they are like 3 dollars). If the orifice tube is covered in debris or black colored slime, your AC system will need a lot more attention and I wouldn't bother with a new clutch (you'd probably need a new compressor and condenser.)
If you do open the system/there is a leak, you'll also want to change the accumulator/recieve dryer unit. It should be like 30-40 bucks. It's what keeps the moisture out of the system. When exposed to the air (if there is a leak in the system or the system is opened up), they become "worn out" and can't absorb any more moisture so it's always a good idea to replace them when the system is open.
My brother had a 2001 ford Taurus. His AC compressor clutch went out. We took a risk to replace just the clutch, and it ended up working but only for about a year and a half. The reason the clutch went out was because one of the cooling fans stopped working so the AC condesnor got too hot, making the compressor heat up too much. This cause the clutch to fail, but also damaged the compressor in the meantime.
Also, my compressor seized up about 7 years ago. I didn't know much about AC then, and decided to replace the clutch because I thought I might be fine in just replacing that. Well as soon as I replaced it and turned the AC on, the new clutch burnt up because the compressor was seized and didn't allow the clutch to turn properly when it was engaged. I'd try and make sure your compressor isn't seized if you do put on a new clutch.
I'm not trying to dissuade you from replacing the clutch either, but just be aware that there may be more than clutch problems if it really is bad. Anyways good luck hopefully if gets fixed soon! The hot weather is coming!
What I do when they are not hooked up is just grab the clutch by hand and make sure to reach the plate in the back. Then get some good leverage and try and turn them. If your clutch plate is triangular shaped and has the three studs, you could take the belt off, and try and use a large screwdriver or pry-bar to turn the disk (you want the shaft of the compressor to turn.) I honestly don't know how hard it will be to try and turn the shaft of the compressor while it is hooked up and charged though since you'll be compressing the refrigerant in the system. I would imagine if you go slow, it should still be able to turn no harder than something else on the engine. It should turn easier than the crank pully does that's for sure!
However, the shop would probably have let you know if they thought it was bad because it's pretty easy to replace the condenser and they'd make more money off replacing it so you're probably good. Sometimes you can get ultra lucky and have the orifice tube catch any remaining debris and not affect the AC much as well if the condenser did in fact have debris in it.
Like I said you're probably good, I just like to be picky with AC stuff since it's so important here in AZ.
Then you can add more oil and vacuum the system down, then add refrigerant. The system is probably low on oil since it manages to leak out with refrigerant, so just a recharge may not be enough. You definitely can get by with that for a while, but there is a good chance that prolonged charging will cause issues later down the road.
