Sponsored by: Auxito
AC Problems
Old May 21, 2010 | 03:24 PM
GMAESTRI's Avatar
GMAESTRI
Exclamation AC Problems
Hey
My AC does not blow out cold air when I turn it on AC and Max AC. Its a 2001 5.4 4x4 with 13K miles. I tried adding freon with some stuff I bought at Pep Boys but no luck. I also checked the fuses under the dash and in the distribution box. It doesnt blow out warm air but its definately not cold. Any help? Thanks. And I have never replaced an AC before so any steps for taking stuff apart will help.
Also when the AC is on the clutch stops spinning and makes a click sound and then will turn on again but repeats every couple of seconds. Didnt know if thats normal?
Old May 21, 2010 | 07:44 PM
projectSHO89's Avatar
projectSHO89
Go to the HVAC forum and read the FAQs.
Old May 21, 2010 | 08:19 PM
steve(ill)'s Avatar
steve(ill)
the compressor has a low pressure switch that cuts out about 20 psi. when the pump starts to pump, it sucks the suction side down and if it falls below the low pressure switch setting ,it kicks out. That is what is happening. Yoour pump should run almost constantly. Your low on R134. It would be best to have a pressure gauge so you know what your doing. Just adding another can might work, but thats not the right way to do it.
Old May 21, 2010 | 11:03 PM
93 mix 'n match's Avatar
93 mix 'n match
im no AC expert, but my mechanic said theres a switch on the passenger side of the truck that tends to go bad. he'll be fixing it tomorrow so ill let you know.
Old May 21, 2010 | 11:47 PM
GMAESTRI's Avatar
GMAESTRI
When I purchased the can it came with a gauge and everything seemed to check out normal and when i tried adding some the gauge did not move. My Uncle and I just figured it is full because it was in the blue I believe, the normal amount that is suppose to be in the line.
And thanks! If it is a switch I would love to know where its at so I can get it fixed. What year is your truck?
Old May 22, 2010 | 08:41 AM
projectSHO89
Repeating: Go read the FAQs! Your question is covered THERE!
donovan
6.7L Power Stroke Diesel
23
Oct 8, 2012 09:27 AM
4x4_EB_Explorer
Jan 5, 2008 08:45 PM
97EBXPLORER
Jul 16, 2004 08:02 PM
97EBXPLORER
Jul 12, 2004 08:36 PM
