AC not working
Old Aug 28, 2006 | 01:53 PM
96DRW's Avatar
96DRW
AC not working
Hello all,
I have a 96 F350 with 44k on it. About a month ago the AC stopped working. The clutch does not engage (start turning) when I turn the AC on. Using my test lamp I can tell I’m getting power to the AC pump. I hooked up a pressure gauge to the low pressure port of the system and it read about 100 psi, (too high?) the AC clutch was not engaged or working though. Any ideas where I should go from here? Thanks.
Old Aug 28, 2006 | 06:34 PM
tim73's Avatar
tim73
Originally Posted by 96DRW
Hello all,
Pull the harness from your low pressure switch, and jump it out. Turn it on, if the compressor comes on, then either youre low on refrigerant or the switch is bad(I had the same thing happen and it turned out to be a bad switch)
Old Aug 28, 2006 | 07:40 PM
quicklook2's Avatar
quicklook2
only do this for a very short time like 5 or 10 seconds.
Old Aug 29, 2006 | 10:09 AM
96DRW's Avatar
96DRW
Thanks for the advice. Tim73, where would I find the pressure switch on my rig? Does the AC compressor need to be running to get an accurate pressure reading? Thanks.
Old Aug 29, 2006 | 10:15 AM
quicklook2's Avatar
quicklook2
it is by the heater air cond. box on passenger side of firewall.
Old Aug 29, 2006 | 03:29 PM
quicklook2's Avatar
quicklook2
look for the round cylinder with the air cond. hose/lines to it in front of heater box. on the side of that is the electrical connection you are looking to jump.
Old Aug 31, 2006 | 05:04 PM
96DRW's Avatar
96DRW
Thanks for the reply. I haven't jumped a lot of circuts but I am assuming I can find the hot lead on the pressure switch then run a line to where the hot line connects to the compressor. Do I need to have the engine running or can I just turn the ignition on? What are your thoughts about checking the pressure of the system. Does the AC compressor need to be working to get a meaningful reading to determine if the pressure is too low? Thanks
Old Aug 31, 2006 | 08:48 PM
quicklook2's Avatar
quicklook2
you just unplug the swith and jump that.
have a shop check pressure.
Old Aug 31, 2006 | 10:50 PM
dave2's Avatar
dave2
Sorry to jump in on someone elses post (again), but any idea what coolant was used in a 1990 (R12 or the R134)?
Thanks
Old Sep 1, 2006 | 07:34 AM
subford's Avatar
subford
Thanks
1990 would be R12.
Old Sep 3, 2006 | 01:30 PM
tim73's Avatar
tim73
To jump out the switch, remove the wire from the switch(The switch is the little thing screwed into the side of the accumulator(Theres is a schraeder valve there, like the one on tires, so if you need to replace it you can without loosing all the refrigerant). Then attach a wire across the two leads on the wire harness you just removed. i use a paperclip alot of times. All the switch does is open up(Break continuity) when pressure gets too low(Or if the switch fails it will fail open). The AC system relies on the low pressure circuit being continuous. This switch tells the system when to turn the compressor on and off, so it is very important and seeing as it cycles alot, prone to fail.
Old Sep 4, 2006 | 08:24 PM
96DRW's Avatar
96DRW
Thanks for the help. I'll try the jump and go from there.
Old Sep 4, 2006 | 08:55 PM
puck1263's Avatar
puck1263
The compressor must be running to get an accurate refrigerant reading. Make sure you check the low pressure side.
Old Sep 11, 2006 | 11:18 AM
96DRW's Avatar
96DRW
I want to thank everybody for the help. Yesterday I disconnected the Pressure Switch intending to jump it. Before jumping it I decided to spray some electric contact cleaner on the connections. What do you know...the A/C fired up! I guess it always pays to try the simple stuff first. Thanks again.
Old Sep 11, 2006 | 11:43 AM
quicklook2's Avatar
quicklook2
that is good news.
always trying the easy stuff first is a good rule.
