Bad AC Accumulator Switch
Old Apr 9, 2012 | 05:07 PM
tshrager's Avatar
tshrager
Ok, I just did the paperclip in the accumulator switch harness to see if this was the reason my AC clutch wasn't engaging. The compressor clutch fired right up. Now my question is (I know jack $&%# about AC systems) if I replace the switch is anything under pressure in the can that I will lose or is it just a simple R and R?
Old Apr 9, 2012 | 05:10 PM
rodneywar's Avatar
rodneywar
the switch is removable just unscrew it and put the new one on it has a schrader valve to keek the freon from escaping under the switch
Old Apr 9, 2012 | 05:21 PM
tshrager's Avatar
tshrager
Sweet, that's what I was hoping to hear, Thanks Ronnie!
Old Apr 9, 2012 | 06:26 PM
fordpride's Avatar
fordpride
When you jump the switch does it blow cold?
Old Apr 9, 2012 | 06:39 PM
tshrager's Avatar
tshrager
The write up said not to jump it very long and it's not hot here for the next couple of days. What I do know is that the clutch will not engage. Jumped it does. I see where you're going with this mike. Low on refrigerant. Dang I need a set of gauges!
Old Apr 9, 2012 | 06:44 PM
fordpride's Avatar
fordpride
Go get you a recharge can of 134a that has a gauge on it from autozone
Old Apr 9, 2012 | 07:10 PM
tshrager's Avatar
tshrager
From what I've read those gauges are junk. I'll see if I can swing up to my buddies work. It'll look funny parked in there with a bunch of Lexus'
Old Apr 9, 2012 | 07:32 PM
fordpride's Avatar
fordpride
Actually they are pretty close
Old Apr 9, 2012 | 07:46 PM
Ken_C's Avatar
Ken_C
Close enough for the one or two times it'll get used. the low pressure switch is probably fine. its not a common failure item. more likely that the system has a low charge. which means it has a leak somewhere.
Old Apr 9, 2012 | 08:01 PM
tshrager's Avatar
tshrager
The more I think about it, the more its starting to sound like a leak. The $20 switch is waaay to easy of a fix. Luckily the temp hasn't gotten crazy like it did a few weeks ago. Sounds like a trip to my buddies is in order
Old Apr 9, 2012 | 08:03 PM
bearhugger's Avatar
bearhugger
Mine was loosing freon also,found that the schawder valve up by the compressor was leaking,pushed it in and out a couple times and it sealed ok;put more freon in using the auto zone set up and no more problem.
Old Apr 9, 2012 | 08:13 PM
fordpride's Avatar
fordpride
I'd put a can in it and see how long it last
green_95
28
May 13, 2016 12:44 PM
f1504x4driver
Nov 10, 2011 10:08 PM
Bobert
Sep 1, 2008 09:17 PM
hamsteria
Jul 21, 2008 08:35 PM
96DRW
Jun 5, 2007 11:59 AM
