Headlight Buzzer?
Old Mar 25, 2016 | 07:31 PM
64rednwhite's Avatar
64rednwhite
Headlight Buzzer?
I'm a chronically leave on my headlights and all my neighbors are tired of having to tell me I've left them on. So I'm trying to hook up a buzzer to remedy the problem and can't figure it out. Maybe one of you FTF'ers has experience with this? According to what little I can find on line, it seems I can hook up my piezo buzzer red to the lights fuze and black to ignition? Any help will be greatly appreciated! I've attached a pic of my fuze box ('64 F100) and the piezo...
Old Mar 25, 2016 | 09:47 PM
IICAP's Avatar
IICAP
My thought is red to headlight circuit and black to a oil pressure switch for an idiot light. When you shut the engine off the switch will ground and set off your buzzer. If you hook to ignition, I guess you might need a relay that would ground when the ignition is off and open when ignition is on
Old Mar 26, 2016 | 11:52 PM
62fordF250's Avatar
62fordF250
I'll second IICAP. You want your power to come from the light circuit (probably parking lights), but the ground should only be available with the key off... IICAP hit the two easiest ways to do that.
Old Mar 27, 2016 | 05:50 AM
F100 wannabe's Avatar
F100 wannabe
I was thinking splice the positive to the headlight output from the switch, and connect the negative to a door switch like this.
One thing to remember, when the headlights come on, the parkers go off. SO if you connect the switch to say the headlights, it won't activate for the park lights and vice versa.
Old Mar 27, 2016 | 07:40 AM
john jamieson's Avatar
john jamieson
They used to sell buzzer kits for this purpose. You might try looking for them. You may be able to see how they do it. I put one in a gmc blazer I had but that was almost 20 yrs ago.
Old Mar 28, 2016 | 08:42 PM
64rednwhite
Thanks for all the helpful replies! I guess what I'm in need of here is a little hand holding. You say red to headlight, is the light circuit fuse the one at the top of my picture? Which end does red go to? If I had that, then I can find the other connection through process of elimination. By the way, this buzzer is LOUD. It's going to train me to always turn off the lights or get blasted!
Old Mar 28, 2016 | 08:45 PM
markeyd's Avatar
markeyd
Good project. I need that. When you get it figured out let us know how you did it.
edit: found this:
DIY instructions:
http://www.gmcmhphotos.com/photos/data/5969/test.pdf
and these kits:
http://www.summitracing.com/parts/sd...rstRoCb0Hw_wcB
https://www.vellemanstore.com/en/vel...FGsxoCR9Xw_wcB
mikemass
Jan 14, 2023 02:44 PM
SkipTLoo
Jun 14, 2011 11:11 PM
GubNi
Oct 19, 2009 08:21 AM
a564jim
Aerostar
Jun 30, 2004 07:25 AM
Dj300ford
1983 - 2012 Ranger & B-Series
May 2, 2004 01:06 AM
