Headlight problem
Old Jun 14, 2011 | 07:34 PM
SkipTLoo's Avatar
SkipTLoo
Headlight problem
I've have aftermarket headlights that are blue in color. Problem I'm having is that the headlights will flash on and off about whenever it feels like it. Since then I've put new original headlights in. No tested them yet. I also replaced dimmer switch thinking that could be the problem.. But no. On off on off....samething lights in and out.. Would you think that the aftermarket lights overheat the switch... Or is there something I could also check.. One more thing is there a free place to get a step by step thing to replace my turn signal switch.
1974 Factory Highboy f250 w/ 390
Thank you,
Skiptloo
Old Jun 14, 2011 | 07:37 PM
fmc400's Avatar
fmc400
MSEE
The switching off and on means the circuit breaker in the headlight switch is interrupting, meaning you're drawing too much current downstream of the switch. This can mean the headlight bulbs are incorrect, or there is a short somewhere. Test it with the original headlights, and then check for frayed or pinched insulation between the headlights and the switch. I'm sure you know this already, but the headlight switch wasn't the problem - the old one was preventing an over-current condition, just as the new one is.
Old Jun 14, 2011 | 09:23 PM
Ryank78shortbed's Avatar
Ryank78shortbed
do a relay and wiring upgrade on the light system!
Old Jun 14, 2011 | 11:11 PM
The Confederate's Avatar
The Confederate
Here's a link to another thread that has a wiring diagram I made for the rewiring upgrade. It will stop the flickering lights and also take the main current from the switch to the relays!
https://www.ford-trucks.com/forums/1...g-upgrade.html
dennis112
Dec 4, 2021 01:00 AM
ProjectDaisy
Jan 18, 2016 04:35 PM
mustangpt
Apr 22, 2015 09:59 PM
94 7.3idi
26
Apr 29, 2012 09:31 PM
AndeyHall
Oct 30, 2010 03:32 PM
