2000 f150 4.2 need help P0171, P0174
2000 f150 4.2, pulls codes p0171 and p0174 (lean on both banks). Have installed new MAF sensor, replaced intake gaskets. Seems to run ok except idles 'bout 980 RPM. Have checked for vacuum leaks (starting fluid, carb cleaner and water. I will clear codes and they will be back 2-5 miles. Any and all help welcome
171 - 174 are almost always vacuum leaks. Easiest thing to check is all the small rubber hoses from the manifold to EVERYTHING. Truck is 16 years old... rubber gets hard / cracked / brittle ... small leaks. Pull one hose off at a time and check for flexibility and cracks.
2000 f 150 4.2 v6 232,000 miles
