Sponsored by: Auxito
p0171 and p0174 codes
Old Feb 21, 2007 | 11:12 PM
micker030's Avatar
micker030
I have a 99' f150 4.6l and i just did a plug and wire job on it..20 miles later its throwing a p0171 and p0174...anybody help?
Old Feb 22, 2007 | 09:00 AM
projectSHO89's Avatar
projectSHO89
You now have a vacuum leak which might be anywhere between the MAF sensor to the intake to any of the hoses coming off the manifold, including the notorious PCV hose elbow.
Steve
Old Feb 22, 2007 | 10:54 AM
beekermartin's Avatar
beekermartin
Check all your vacuum lines. I had the same problem. I found three hoses that had holes in them. There are a lot of hoses but start at the pcv valve. You'll probably find the problem there.
