Computer Chips & Tuners
96 F350 "computer"
Old Mar 23, 2016 | 03:48 PM
didev's Avatar
didev
96 F350 "computer"
Need some help please. My mother, who lives in Arizona, has a 96 f350 with an auto trans and a 460. A while back the thing just died on her. She tried getting help from friends in the area, but no one could figure out the problem. She finally had someone diagnose the issue as a problem with "the computer", which I can only assume is the ECU. She is now being told that "the computer" can only be replaced at the dealer, at a cost of $3-5000.00. I checked ebay and have found ECUs for her vehicle in the $200 range. She says she is now being told by the dealer that "they have to uninstall programs from the old computer, and install programs with the new computer." I thought these ECUs were preprogrammed for the vehicle you buy them for? This whole story just isn't making sense to me. It's difficult for me because I live 3000 miles away from her, so all of the information I'm getting is second hand. If anyone could help me out I'd appreciate it. My mother is elderly and doesn't have any money, and she needs the truck to haul water to her property, not to mention grocery runs to town and stuff. She is now entirely dependent on the good will of others to help her with her water and stuff. Thanks in advance.
Old Mar 23, 2016 | 04:39 PM
Conanski's Avatar
Conanski
Yeah the dealer is feeding her a massive pile of BS, a '96 F350 uses the old OBD1 EFI system which is not flashable at all so there is no way to remove or add "programs". The PCMs you are finding on eBay are the right thing you just have to determine her vehicles exact requirements, see if she can get a picture of the calibration code to send to you, it's usually on the drivers door frame somewhere.. on the cab portion not on the door itself. That calibration code will tell you what PCMs are exact replacements. I'd wager the truck has an E4OD trans and that is another key thing to know because the PCM also controls the trans.
Old Mar 23, 2016 | 04:58 PM
didev's Avatar
didev
Thanks
Thank you very much, I will relay that info to her.
One other question. She's also telling me that no one other than the dealer will touch the truck. Just how complicated of a job is it to swap out the PCM? I thought it was relatively simple. Am I wrong?
Thanks again.
Old Mar 23, 2016 | 08:11 PM
Conanski's Avatar
Conanski
Yeah sorry... its brutally complicated. First disconnect the battery, then loosen and backoff the 10mm bolt that attaches the wiring harness to the PCM at the firewall on the drivers side of the engine compartment so that the harness connector can be removed, and then pull the PCM out of it's pocket in the drivers side finder.
Old Mar 23, 2016 | 08:58 PM
didev's Avatar
didev
Thanks again
That's what I thought, thanks.
I have no idea why the dealer is telling her this nonsense. She's not going to spend that kind of money on that truck, so what do they have to gain by telling her that? I don't get it.
Old Mar 24, 2016 | 10:20 AM
Conanski's Avatar
Conanski
I'd say the parts counter guy or whoever she is talking to has absolutely zero knowledge of these trucks and assumes that because it's a '96 that it is OBD2 and therefore the same as a current vehicle, and he is then quoting the typical shop rate for this work plus a 100% markup for unexpected surprises. Or he is a complete sleaze ball looking to take advantage of someone.
Old Mar 24, 2016 | 01:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
He quoted MUCH more than 100% markup. Much, much more.
704 dentside man
22
Apr 14, 2024 12:07 AM
jluneau
16
Sep 30, 2011 08:48 AM
phoenix44
Dec 1, 2009 05:45 PM
doug96
Feb 2, 2005 09:13 PM
ojedabr
Feb 2, 2004 10:24 PM
