96 460 F350 ECM
96 460 F350 ECM
I just picked up a 96 350 4x4 with 460/e4OD for cheap. For whatever reason the PO thought the original computer was bad, took it out and lost it. Replacing the ECM would be easy if it weren't for that.
1) so how do I go about making sure I get the correct ECM the first time, I'm seeing a few options for this combo. See if a dealership can tell me based on the VIN???
2) will the ecm be good out of the box, or will I need to get it reprogrammed?
I swapped in a manual trans computer before I bought the truck to make sure it would fire and move...it does in first gear, but nothing in dash worked (I'm assuming because of wrong computer???). Thanks in advance.
And that's where my confusion is coming in to play...why all the different calibration codes (and what do they mean) if they're all the 'same'. One thread someone says the truck will catastrophically fail, another someone says they all swap.
on
Think about it this way. SAME injectors, SAME distributor, SAME oil pressure sensor, SAME coolant temp sender. NOTHING is different other than the code on the ecm
There is a difference in the programming for 1994 and later trucks. The computer controls the dwell time for the ignition. That's why it's called Computer Controlled Dwell ignition.
Ford also moved the transmission solenoid protection diodes from the transmission to the computer in 1995. Running an earlier computer (PCM) on a 1995 or newer vehicle could result in damage to the computer since there will be no suppression diodes in the circuit.
Best bet for a swap is a 1995 or later PCM. Or to be safe post the calibration code sticker info so someone can decode it for an exact swap.
Different 460 PCM use use different number of solenoids in the Secondary Air Injection system and also different number of O2 sensors. This will cause the so called Check Engine Light (MIL) light and post codes in CM.
I ran into this problem trying to find a spare PCM for my 1994 460 set up.
