Dually Swap
Old Mar 29, 2016 | 07:18 PM
  #31
timmyboy76's Avatar
timmyboy76
[QUOTE=Absolute;16163799]Got the new axle all done. Managed to get the shocks at Lordco. Cost more, but get the rebate and no shipping and waiting. That said , everything rides fantastic, tight and smooth. And I still need to get an alignment. Might wait until I put the new rims and tires on since it rides perfect. Shocks seem great, even though I have them on a low setting. That said. I have a question on shocks. The stocks are different because of the metal shroud and no rubber boot, so comparing was difficult. When I stand next to the truck looking at the 9000's, The rubber boot is compressed and only about 4" of rod is extended. I compressed the old stock shock and it appeared close, but the shroud limited seeing how much rod is exposed compressed. Is 4" normal on a stock suspension? I read the spec and it has 7.75" of travel, so 4" would appear to me to be in the middle, and normal, but it looks odd with the boot all the way compressed like that. Any reassuring thoughts??[/
Is there a way to install a sprite around the shaft, then go drive ur, take off the road..etc, then evaluate where the ziptie ends. If not bottomed out, I'd say ur good to go....as for your 1st thread question, was tho what you were after... http://www.riffraffdiesel.com/front-abs-grease-able-block-off-fitting/
Old Mar 29, 2016 | 07:23 PM
  #32
Absolute's Avatar
Absolute
They just look compressed all the way because of the red boots being compressed. But there is actually about 4" travel exposed. It rides great, so figure there the right ones. Thought they might be too long and the girl gave me the wrong ones.
Old Mar 29, 2016 | 07:25 PM
  #33
Absolute's Avatar
Absolute
I looked that fitting up. I'd do it but I want to keep my antilock brakes working. So can't do it.
Old Mar 29, 2016 | 07:37 PM
  #34
scotttahoe's Avatar
scotttahoe
This is how mine look without the rubber boot. I still have to do the rears but ran into a big problem and will start another thread when I can tackle it.
Old Mar 29, 2016 | 09:11 PM
  #35
Absolute's Avatar
Absolute
Is that Pic with the suspension compressed? Looks like its hanging. If so mine are fine. Mine has 4" compressed all the way, full truck weight. I also notice you have a lot of spings in there. Mine has only 2 leafs. That said, you shock top looks like it ends level with the frame, then the rod. Mine is an inch higher than the frame then the rod. You must have a lift on there. Any stock guys have a pic to compare??
Old Mar 29, 2016 | 09:54 PM
  #36
scotttahoe's Avatar
scotttahoe
I do. It's a 6" lift far from stock. The trucks weight is sitting on the leafs. I have a jack stand under the front axle.
Old Mar 29, 2016 | 10:34 PM
  #37
Absolute's Avatar
Absolute
OMG! Just did some number searching on the Rock Auto site for those shocks, and Lordco sold me the ones for a 2.5 to 4 inch lift. So off they come and back to Lordco for the right pair. Explains everything. Thanks anyway guys.
Old Mar 30, 2016 | 10:18 AM
  #38
scotttahoe's Avatar
scotttahoe
That stinks, they are messing with you now.
Old Mar 30, 2016 | 07:15 PM
  #39
Absolute's Avatar
Absolute
Got the new shocks in. Yup, about an inch shorter, and looks much better. Had to wait all day to get them. Weren't in stock. Lol.
HAWG06
Apr 21, 2012 08:36 PM
meier63
Aug 18, 2011 10:00 AM
KRDiesel
Sep 12, 2009 02:22 AM
convincor
Jun 28, 2005 02:46 PM
RobertJohn
Feb 10, 2005 10:15 PM
