Fuel pressure problem/hot start
Parts:
http://www.riffraffdiesel.com/high-p...0l-late-build/
http://www.riffraffdiesel.com/high-p...ed-dummy-plug/
https://www.ford-trucks.com/forums/1...s-and-stc.html
You'll need a 10mm and 12mm hex bits to get them out then back in, the size changes on the new parts.
You really need a gauge to verify a high pressure oil leak or you'll keep tossing parts at it:
https://www.ford-trucks.com/forums/1...eral-info.html
This shows you how to get down to the passenger side (the more difficult side because of clearance issues with the HVAC box). He removes that standpipe starting at 4:50, he calls it "crankcase to head plug". He skips the dummy plug removal, it's out but you can see the hole for it that has a green o-ring in it in the front upper right corner of the oil rail while he's removing the stand pipe:
