Need expert help
Old Nov 7, 2011 | 07:40 PM
Steadyman321's Avatar
Steadyman321
Need expert help
I have an 06 350 6.0. On cold starts it turns over for 8-10 seconds before firing up, it starts normal after the motor is warm..... any ideas? thanks for any and all advice.
Old Nov 7, 2011 | 07:52 PM
BLADE35's Avatar
BLADE35
Im no Expert but Id be for checking the FICM Voltage
try this
https://www.ford-trucks.com/forums/8...procedure.html
does it run ruff when cold
any gauges
Old Nov 7, 2011 | 08:50 PM
ambrose2004's Avatar
ambrose2004
i am also no expert by far. but i have heard a lot of stuff and verified a lot of it from my ford friends. i have heard that injector o rings can cause that cold start problem. apparently it lets air into the fuel system and doesn't start right away. but ficm would def be easier to check.....
Old Nov 7, 2011 | 09:18 PM
BLADE35's Avatar
BLADE35
I had that problem with Injector o-rings
its sufferring from Low Fuel Pressure cuz the Orings didnt seal and fuel escapes from the injector cup causing Low fuel pressure
I knew it because I was making oil and the oil really smelled like Diesel fuel it would make a quart of oil every 2 weeks
It wwould start normal it just ran rough and misfire and tranny wouldnt shift right But everything was fine when warmed up
I reringed all 8 injectors and problem solved
Old Nov 7, 2011 | 09:19 PM
BLADE35's Avatar
BLADE35
Old Nov 7, 2011 | 10:27 PM
Steadyman321
I'm going to check the voltage on the ficm, truck doesn't blow any smoke ever and runs smooth all the time. Just starts funny when the motor is cold. And the way the truck snaps when it finally starts sounds/feels like it wasn't getting any fuel, so I wasn't sure if my fuel pump was going. I put new fuel filters in a thousand miles ago and the guy who owned it before me kept a maintenance/repair log and the truck hasn't had any big problems yet. Thanks for the help.
Old Nov 8, 2011 | 09:10 AM
dchamberlain's Avatar
dchamberlain
What brand oil and fuel filters do you use?
Old Nov 8, 2011 | 11:03 AM
BLADE35's Avatar
BLADE35
Get some gasuges to start checking some things out
David makes a good point the wrong filters on these trucks can be Catastropic
clean the egr valve too
Old Nov 8, 2011 | 11:21 AM
Steadyman321
Ok, the ford dealership that I bought it from changes the oil for free for the next year. I'll look into what they use.
Old Nov 8, 2011 | 11:47 AM
bpounds's Avatar
bpounds
I would be checking FICM voltage, high oil pressure during cranking, and fuel pressure.
Axle rose
Jan 9, 2017 06:44 PM
bismic
Jul 12, 2016 01:11 PM
Mowing Man
Jul 29, 2012 08:07 PM
solaratomic
Apr 12, 2010 01:22 PM
Big
Oct 21, 2006 07:08 AM
