I have the mastercool 71475 kit, I like it because it is portable, you are not forced to make the flares at the bench. I have done double flares right at the vehicle when making repairs. I also needed to be able to make GM style fuel line flares which this tool does as well. I have not tried the eastwood tool but I have found that their tools are good quality items.
Once you get your flaring tool you might want to look at S.U.R.&R brake line. Once you have used this type of line you will not want to use anything else.
The Eastwood flaring tool arrived today. I made a couple of practice flares to see how it works. It does a beautiful job and is as fast as they show on the video. I am very pleased. Thanks for all the help.
Mark
In the comments on the link, it describes the line as "steel". Is it steel or cunifer copper-wound line?
I not sure exactly what it is made of Ross but it sure is easy to work with. It has to be some form of alloyed material because it is a lot easier to form than a normal steel line.
I have the K-tool lever type. I used it for 37 degree JIC/AN stainless steel lines on my 1969 Mustang's brakes and all the JIC/AN flares on my F1. It does AMAZING work on soft metal. Best $180 I have spent on a tool
Mark
Glad it worked out for you. It's actually fun to use isn't it?
Thanks for the link Chuck. I have a roll of 1/4" steel line the I bought locally that I will probably use. I tried a couple of flares on it and it flares beautifully. I used the same brand of 5/16" for my fuel lines that I ran a couple of weeks ago. It bends really nice.
Thanks , Mark
Mike, I believe the K-tool is what Summit sells. It looks identical to the Eastwood one that I ordered. I agree, I think it was a very good investment.
Thank, Mark
Nick, I have been actually dreading making the brake lines. I really enjoyed bending and fitting my fuel lines but, I didn't have to double flare anything. The Eastwood tool will put the fun back into running the brake lines.
Thanks again, Mark
I have the K Tool version and I bought the 37 degree dies from Eastwood. Both Eastwood and K Tool, seem to be the same tool, just re-branded. Perfect flares every time.
