1986 f150 help
Old Mar 19, 2016 | 03:43 PM
76shovelkicker's Avatar
76shovelkicker
1986 f150 help
I have an 86 with a 300 but the block is locked up so I'm looking to drop a 302 in but I don't know what type of manual transmission will work? Will the inline 6's 4speed 1st granny toploader bolt onto the 302?
Old Mar 19, 2016 | 06:26 PM
BTFordGuy302's Avatar
BTFordGuy302
I have a 4-speed toploader in mine so yes, it should!
Old Mar 19, 2016 | 06:34 PM
Gary Lewis's Avatar
Gary Lewis
The 300 six and the small blocks share the transmission bolt pattern. So your transmission will bolt up although you will need the flywheel. Plus you'll need the engine stands that bolt and rivet to the frame, a different radiator, a small-block engine wiring harness, and exhaust.
Old Mar 19, 2016 | 06:35 PM
ryry46d9's Avatar
ryry46d9
I think the bell housing is the same but you might have to use a 302 flywheel
Old Mar 20, 2016 | 01:02 AM
76shovelkicker
For the engine stands are you talking about motor mounts? Not to worried about exhaust yet I live in flagstaff Arizona... There's no emissions!!!
Old Mar 20, 2016 | 01:16 AM
76shovelkicker
Also what about the clutch?
Old Mar 20, 2016 | 05:49 AM
FuzzFace2's Avatar
FuzzFace2
No not the rubber motor mounts there are metal brackets that the motor mounts rest on the are bolted to the frame they are different between the 300-6 and 302-v8
I would think besides the flywheel to match the 302 v8 you would need the clutch disc & pressure plate also.
Dave ----
Old Mar 20, 2016 | 07:42 AM
Gary Lewis's Avatar
Gary Lewis
The engine stands are discussed here: Engine Perches - Gary's Garagemahal
The clutch from the six may work on an eight. The difference will be in the size/diameter. Some sixes came with a small clutch, but the 302 doesn't have much torque so a small one should work with it.
Sibobbs
Jan 22, 2012 04:55 AM
Kuskoal
May 4, 2009 11:15 PM
Weaponrider
Sep 5, 2006 07:27 PM
rustydog628
May 7, 2003 09:27 PM
slimersoup
Sep 16, 2001 08:11 PM
