bolt pattern for flywheel/flexplate
Old May 2, 2009 | 09:41 PM
Kuskoal's Avatar
Kuskoal
Is the small block ford bolt pattern used for an inline also? If it I'm gonna knock the weights off the 302 one im required to buy to swap a stick in
Old May 4, 2009 | 11:15 PM
F-250 restorer's Avatar
F-250 restorer
flex plate pattern
I just went through the same thing. Yes, the bolt pattern is the same, but the 300 flex plate does not have the heavy balance weight. And it has 164 teeth, so put a mark on one, and start counting to be sure.
Also, the 300 plate has a few 'cut outs' which the v8 plates do not, and I'm guessing THAT is for balance. Everything else is the same. A new one runs about $40 in the discount houses.
bsneed
Dec 28, 2016 01:29 PM
Badchuck4
Aug 15, 2016 10:35 AM
460/5
23
Nov 18, 2009 04:49 PM
l67cooled
Nov 12, 2009 08:51 AM
systemofadowntox
Aug 3, 2004 06:37 AM
