Hey just finished putting 8 injectors in my 2003 f250 6.0 v8 power stroke got it all back together no crank and no fuel pump when I turn the key I checked all fuses relays determined the ignition switch is good the starters good cranks over good by useing the wire on passenger side fender when touching the positive post checked ipr and icp both good connections so I removed the first plug to pcm on drivers side fender with the key turned to run and fuel pump worked pushed it back into pcm and fuel pump stopped working wondering if the pcm was bad would that cause no crank and fuel pump not to get power from key
yes it is, along with a couple other relays. You could change then around for a test if needed, they are the same size.
I tryed switching relays they seem to be all good doing same thing just stumped why when I pull that first plug out of pcm the pump starts working and still no crank from key
Look closely at the connector and wires at the fan shroud for the fan clutch. Another posibility is the EBP sensor and its wires or connector. Crank is being inhibited by the PCM because it is seeing something it doesn't like. One posibility is shorted vRef voltage at any of the sensors. These two are just the most common problem areas. This power comes from fuse f2-22 (under the dash) check it specifically. Also make sure the blades of the fuses are between the clips in the fuse box. It's possible to put the fuse in with the blades beside the clips and make a poor connection. It will look like it's in there right but it isn't.
hey never believe what I found I was checking the ficm relay again and if I hadn't dropped a socket which fell behind undernieth the ficm relay bracket as I was searching for socket felt a wire so I took of the bracket and a rodent had chewed 4 wires so I reconnected them and now it cranks from key and fuel pump is working thought I'd post this incase someone else has same issues as I would never of seen this if I hadn't drop a socket lol crazy that 5 mins of chewing can cause 5 days of frustration all good now thanks everyone for your help
