OMG
Old Dec 27, 2015 | 06:42 PM
killing me slowly's Avatar
killing me slowly
OMG
Someone please help.
I'm a new owner of a 03 f350 I have 6.0 motor with brand new top injector orings by Allied HHC bullet proof nipple cups with Viton orings I can't get oil to stop bleeding out.
I've taken apart reinstalled 3 times with same results.
I've searched forum all I've seen is I'm doing something wrong.
Old Dec 27, 2015 | 06:51 PM
timmytoes's Avatar
timmytoes
Where's it leaking? Is it when you crank?
Old Dec 27, 2015 | 06:52 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Have you primed the oil rail? I have no experience with the 03 log rails but the wavy rails have plugs that can be removed to prime the rail. That tends to help you get it started. It is difficult to get all the air out and get oil around those o-rings in order to get it fired off.
Old Dec 27, 2015 | 06:55 PM
killing me slowly
When I'm running it with valve cover off
Old Dec 27, 2015 | 06:57 PM
killing me slowly
I have truck running oil rail even slightly warmed pretty sure it's primed.
Old Dec 27, 2015 | 06:59 PM
killing me slowly
from where nipple goes in injector I have truck running not cranking
Old Dec 27, 2015 | 07:00 PM
timmytoes's Avatar
timmytoes
When you installed the upper injector oring, did you make sure to put the oring on the very top? Is it coming out from the around the injector and can you tell if it's coming from the seal between the nipple cup and the oil rail or the nipple cup and the injector oring?
Shaneb75's Avatar
Shaneb75
Strokin Okie
Oh ok. Have you taken the truck out and run it down the highway? Are you experiencing a hard/no start hot?
Old Dec 27, 2015 | 07:28 PM
killing me slowly
Yes at the top I did without pulling c clip like on YouTube. Not leaking from rail I changed nipple cups because of this problem I had same problem before I changed nipple cups. It leaks where nipple goes into injectors
Old Dec 27, 2015 | 07:30 PM
killing me slowly
Yes hot no start this is why I was replacing top injector seals
Old Dec 27, 2015 | 07:47 PM
mhoefer's Avatar
mhoefer
Did you blow out the holes for the hold down bolts with compressed air? Make sure you got all o rings and copper washers accounted for?
Old Dec 27, 2015 | 07:54 PM
timmytoes's Avatar
timmytoes
Man, it sounds like the oring got pinched or something. Almost sounds like the nipple cup isn't sealing good in the injector. Wish I was more help than stating the obvious. Sorry.
Old Dec 27, 2015 | 07:55 PM
killing me slowly
Yes all parts accounted for.
No did not blow out rail mount bolt holes out but they are clear maybe a little oil in them
Old Dec 27, 2015 | 08:00 PM
timmytoes's Avatar
timmytoes
Just so I'm clear, is the leak in the same place it was before or is it all injectors?
Old Dec 27, 2015 | 08:01 PM
killing me slowly
[ QUOTE=timmytoes;15897549]Man, it sounds like the oring got pinched or something. Almost sounds like the nipple cup isn't sealing good in the injector. Wish I was more help than stating the obvious. Sorry.[/QUOTE]
Oring are good I bought a second set made by Allied first set was made in China that I noticed after I installed them.
Yeah I don't get it Appreciate ur ideas though Thx.
