Front drum backing plate
Old Mar 18, 2016 | 06:23 PM
Shane Carruth's Avatar
Shane Carruth
Cleaning my backing plate to place some new brakes on and noticed that the high points had some serious wear points. I'm not having any luck finding a new backing plate. So...I've seen fixes from grind them all flush, to filling the grooves with JB weld and then grinding the high point flush. I would prefer to replace the backing plate but I'm not finding any for a 65, so is there a year range that I can look at?
1965 Ford F100
Old Mar 19, 2016 | 09:52 AM
resonateur's Avatar
resonateur
Shane:
I may have what you're looking for as I still have some 65 parts remaining. I'll check today. I wouldn't use JB weld on anything that's mechanical...only esthetic considerations. It doesn't make sense. Do you need just one or two backing plates?
Old Mar 19, 2016 | 10:01 PM
Tedster9's Avatar
Tedster9
JB-Weld is good stuff. It won't work on high temp stuff like exhaust manifolds or immersed in gasoline but that's about it. The hot setup of course, is welding a bead and grinding it down.
"Like metal, J-B WELD can be formed, drilled, ground, tapped, machined, filled, sanded, and painted. It stays pliable for about 30 minutes after mixing, sets in 4-6 hours, and cures fully in 15-24 hours. It's water-proof; petroleum-, chemical-, and acid-resistent; resists shock, vibration, and extreme temperature fluctuations, and withstands temperatures up to 500° F. J-B WELD is super strong, non-toxic, and safe to use. Before it sets, you can clean up with soap and water."
All it takes is a skim coat to fill in the grooves and just let it cure. Lubricate the pads with Syl-Glide or equivalent. Tried it on my 64's rear backing plates as an experiment, it seems to hold up just fine. Inspected the drums and new hardware just the other day, in fact. We'll see how it goes.
Old Mar 20, 2016 | 12:24 AM
resonateur's Avatar
resonateur
I agree with Tedster's assesment that the better solution is to weld and re-dress, or use a better backing plate. Some people are fans of JB weld and other epoxies and I think they have their place...but, after all, it was steel that wore away the first time around. I also get it, that it took years to wear out but why not build it to last for the same effort...?
Old Mar 20, 2016 | 10:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Shane Carruth
Cleaning my backing plate (Right or Left?) to place some new brakes on and noticed that the high points had some serious wear points. I'm not having any luck finding a new backing plate. So...I've seen fixes from grind them all flush, to filling the grooves with JB weld and then grinding the high point flush. I would prefer to replace the backing plate but I'm not finding any for a 65, so is there a year range that I can look at?
1965 Ford F100
C5TZ-2012-A Right & C5TZ-2013-A Left .. Front Backing Plates / Obsolete
1965/66 F100 2WD
Old Mar 20, 2016 | 04:27 PM
Shane Carruth
Hey numberdummy, is there a year span that is the same, such as all backing plates from x to y years are the same?
Old Mar 20, 2016 | 05:12 PM
Tedster9's Avatar
Tedster9
Ya kinda hafta reverse engineer what Bill says (sometimes), if there WERE a number of years where the backing plates were the same, he would have said so. It looks like that's it. 1965 WAS a major change for the trucks, the solid axle went away in favor of twin I-beam suspension. By '67 they had made some other changes to body styles and brake options so...
Old Mar 20, 2016 | 05:15 PM
Shane Carruth
Yeah, I'm finding out that getting some parts are a bit difficult.
Old Mar 20, 2016 | 05:18 PM
Shane Carruth
So moving on, does anyone know procedure for welding and then grinding the wear pads. I don't have a welder and would like to be able to tell someone the proper procedures or welding materials needed.
Old Mar 20, 2016 | 08:22 PM
markeyd's Avatar
markeyd
I am not a welder, but I think you just need someone to 'run a bead' along the wear pad to fill in the worn area, then grind it down so it's level with the unworn portion of the pad, and smooth so movement of the pad is not inhibited. I put some high temperature grease on the backing plate, or anti-seize.
Old Mar 20, 2016 | 10:33 PM
resonateur's Avatar
resonateur
Shane:
I do have a set of 65 f100 backing plates. I think a flat rate box will fit it. If you don't want to chase...I'll be happy to help you out, for little more than shipping. In fact, if there's any isssue with the gliding surface I can weld it up and refinish it for you...no extra. Just let me know which side you need.
Old Mar 20, 2016 | 10:47 PM
Tedster9's Avatar
Tedster9
Important thing is you are performing good maintenance, doing a GOOD brake job. People typically ignore the backing plate pads, re-use the old, worn out retracting spring hardware, maybe mix up the self-adjusters, use mismatched worn out cracked drums, two long shoes installed together on a side, two short shoes on the other etc.
The old school mechanic guys say probably half the cars that came in for brake service back in the day were screwed up in some way. We have it pretty easy with the intertubes these days.
Old Mar 21, 2016 | 12:48 PM
NumberDummy
Post #5: These backing plates fit 1965/66 F100 2WD ONLY. If they had fit anything else, or other years, I would have said so.
Old Mar 21, 2016 | 02:09 PM
Shane Carruth
Thank you all, and as usual number dummy your approach and professionalism is always the best. Resonateur I think I've found a set with classic f100s. If that falls through I'll give ya a shout. Thank you again all for your input.
TXtinct
Oct 3, 2011 11:49 AM
Ford_Six
Garage & Workshop
Jul 23, 2007 11:36 PM
hoxiii
Offroad & 4x4
Jan 22, 2004 10:50 PM
Avanti
Garage & Workshop
Dec 1, 2002 01:05 AM
viking
Aug 11, 2002 11:55 AM
