OBDII Code P0150
OBDII Code P0150
My 2010 F-150 Check engine light lit up today. I scanned it to find a P0150 Code. O2 Sensor. Bank 2. Sensor 1. Am I correct it is on the drivers side between the engine and the cat? I haven't looked for it yet. How hard is this to change? What should the cost be to buy one and replace it myself?
Why are you so certain the sensor is at fault? That is a circuit code. Could be a problem with the PCM or the many feet of wiring between the two.
Also, is P0150 the only code? There is a TSB for updated PCM software for vehicles that trip a P0130 at the same time.
There is no 10 year warranty on emissions parts. A few parts are covered for 8/80, the rest are just 3/36 unless you live in California, then some are covered for 7/70.
http://www.ford.com/commercial-truck...ions-warranty/ <--Don't be fooled by the title, it covers cars too
Besides defective O2 sensor and/or wiring ... Other possible causes:
-click- the pic'
Goth 150
< This space intentionally -blank- >
- Exhaust System Leak
- Intake Air System leak (including vacuum leaks)
- Low Fuel Pressure
- Defective Engine Coolant Temperature Sensor
- Defective sensor wiring and/or circuit problem
- PCM software needs to be updated
- Defective PCM
-click- the pic'
Goth 150
Under 36,000?
I have been getting the check engine light which comes on and goes out (after 3 driving cycles) for about a year now. Bought code reader today, read codes. P0103, p0150 Bank1, Sensor 1 and Bank 2, Sensor 1. Is there a TSB on reprogramming? I really do not think the O2 sensors are bad as the light has been on and off very intermittant. Still not sure if it is the brand of fuel. One certain brand seemed to bring it on. I'm sure someone is going to say after the miles I have on this truck they need replaced. Light never stays on past 3 driving cycles and may not come back for a month. Checked all connectors. Thanks.
2010 Lariat Super Crew 190,000 Miles and counting.....
Also something to note; earlier I tested the check engine light and got 3 codes, the P0150 and two others for a TPS and Mass Air Flow sensor. Ford dealer said they only got the P0150, but perhaps the others were caused by this code or the PCM.
