Trailer Reverse Guidance
Old Mar 17, 2016 | 01:44 AM
phydough's Avatar
phydough
I wonder if there is a size threshold of frontal trailer area that it needs. I mean, will it see a little empty boat trailer. That would be cool if it can. Those little trailers that you can't see below the tailgate and inside the fenders will no longer need a spotter.
Old Mar 17, 2016 | 09:13 AM
fordmantpw's Avatar
fordmantpw
Originally Posted by phydough
https://www.youtube.com/watch?v=rjttQNCMDxE
I would assume it looks at the tongue of the trailer, so trailer size should not matter at all.
Old Mar 17, 2016 | 09:17 AM
seventyseven250's Avatar
seventyseven250
Since it's just a camera, I agree, it can see any size of trailer, tall or short, wide or skinny.
Old Mar 17, 2016 | 09:43 AM
Rasalas's Avatar
Rasalas
After watching several videos on the subject it appears that several cameras are involved including not only the tailgate camera (which I know can see small trailers) but also 2 mirror mounted cameras, a high stop light camera and also a front camera. In total there are up to 7 cameras available including one for the adoptive cruise control (helps prevent rear end collisions) and one portable which can be mounted anywhere but mainly designed for the rear of the trailer. All are options and probably available as part of a package.
Old Mar 17, 2016 | 10:36 PM
fzrider998's Avatar
fzrider998
I think you're right. Probably similar to the F150s backup assist....doesn't it use a sticker of some sort on the tongue? This would provide a visual for system to pick up on and sense where things are positioned so it can make suggestions to the driver.
Old Mar 18, 2016 | 07:18 AM
fordmantpw's Avatar
fordmantpw
I know the F150 system uses a sticker you put on the tongue as well as measurements you have to enter into the system. I'm not sure on the Super Duty though.
Old Mar 18, 2016 | 10:04 AM
DerekShiekhi's Avatar
DerekShiekhi
The Camera System on the 2017 Ford Super Duty Can Tell You When You're About to Jackknife
Ford wants to keep the eventual owners of the 2017 Super Duty visually informed, so it's developed a comprehensive system to do just that.
Read the rest on the Ford-Trucks.com homepage. >>
Badger350
May 26, 2017 09:44 AM
Shepardsonp
Jun 30, 2016 11:35 AM
gman97005
General Automotive Discussion
Feb 2, 2016 12:03 AM
medic92
2004 - 2008 F150
Aug 25, 2008 05:56 AM
Tylus
2004 - 2008 F150
Jun 14, 2007 01:59 PM
