C6 speedometer driven gear
Old Mar 1, 2018 | 10:57 AM
hivoltj's Avatar
hivoltj
Hey guys, I had previously swapped the Speedo driven gear to match my 4.10 rear. Now I'm swapping in 3.50 gears and am wondering if anyone knows offhand what gear I need. '77 2wd with 29" tall tires which was a stock setup. The original gear I pulled out won't work as the truck came factory with 2.75 gears. I know I can put it together and calculate based on how far off it is but would rather put the new gear in before I put it back on the road.
Old Mar 1, 2018 | 12:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What series is your truck? Your "About Me" profile says 1994 F150, so obviously this isn't the truck you want the gear for.
How many teeth does the DRIVEN (end of the cable) gear have now?
Old Mar 1, 2018 | 07:17 PM
hivoltj's Avatar
hivoltj
'77 as it says in my first post. Used to all be in my signature is it not anymore? The driven gear I swapped on was I believe 19 tooth. It was one of, if not the highest tooth count.
A 1994 would have neither a c6 nor a speedometer gear
Old Mar 1, 2018 | 07:43 PM
NumberDummy
I know what year it is, but what series is it? F100/F150/F250/F350?
16 thru 21 tooth nylon DRIVEN gears are available from Ford and auto parts stores.
Old Mar 1, 2018 | 10:12 PM
hivoltj's Avatar
hivoltj
F-150
Old Mar 1, 2018 | 10:28 PM
NumberDummy
D0OZ-17271-A .. 21T Nylon Speedometer DRIVEN Gear / Type 2 in pic.
1977/79 F100/150 2WD C6 with 3.50-1 ratio & F78-15; GR78-15; HR78-15 tires.
Info source: 1973/79 Ford 100/500 Series Truck Parts Catalog, P-Metric radials weren't available back then.
Old Oct 22, 2018 | 10:04 PM
webhead's Avatar
webhead
Don't want to hijack this thread, but it is still pertinent to this thread, so hope it's ok.
I have recently taken ownership of a '78 F250 Supercab and have found that the cable is detached from the tranny. The end of the cable at the tranny end is just a cable, and I'm wondering if there's something missing there - seems so, looks like a driven gear based on what I'm reading.
Now, there's a black 'port' on the tranny that seems to be held on by one bolt. Do I pop it off to run the cable through and attach the gear then reattach the bolt?
Thanks in advance!
Dan
Old Oct 23, 2018 | 01:34 PM
resonateur's Avatar
resonateur
Dan:
It sounds like the trans drive end broke from the cable. It should have a "can" shape with O-ring that inserts into the trans and held in with a bolt and plate, and a thinner sleeve that connects to the driven gear. See the image below.
Old Oct 23, 2018 | 01:45 PM
webhead's Avatar
webhead
Well sheeeeeet!! There ain't nothing like that down there I can see. Any danger in my pulling off that "port" to see what's in there? Is this repairable or only replaceable.
Appreciate the image, and response. Very helpful.
Old Oct 23, 2018 | 02:04 PM
NumberDummy
Originally Posted by resonateur
Dan:
New cable doesn't come with the O-ring. DRIVEN gear doesn't come with the C clip used to retain it to the cable (not shown).
87036-S94 .. Speedometer Cable O-Ring - 11/16" I.D. / Available from Ford.
C1DZ-17292-A .. Driven Gear Retaining Clip / Available from Ford.
Old Oct 23, 2018 | 02:19 PM
webhead's Avatar
webhead
So, guessing that means I need to buy a new cable and them bits?
Old Oct 23, 2018 | 02:34 PM
resonateur's Avatar
resonateur
...Dan...take the bolt out and the (port?)...I'm guessing the end of the cable in the trans housing. Once you put it all back together you can see what happened, if it broke. You can buy the cable. Just have to measure yours and make sure the new one has the right end for the speedo end. You can buy the gear, O ring and C-clip.
Old Oct 24, 2018 | 12:23 PM
webhead's Avatar
webhead
Right on, will get at that asap. Appreciate the help y'all!
Old Dec 25, 2018 | 04:05 PM
webhead's Avatar
webhead
FINALLY got around to doing this, and here's what I've got...I'm guessing something is missing between the cable housing and the (what I am calling) port that has the driven gear attached.
This is how the vehicle ended up being in my possession, so, no idea what has gone on down there with the previous owner...
Here they are apart:
Speedo cable out of the driven gear.
Here's what they look like as assembled as I can get them.
Speedo cable inserted as far into the driven gear "port" as it can go....
Anyone know if there's some sort of insert wit ha clip (I'm guessing) that's missing here that would hold the cable's housing in the port? If not, I'm just going to rig something up to hold it all together.
Last edited by webhead; Dec 25, 2018 at 04:07 PM. Reason: The image didn't show up....
Old Dec 25, 2018 | 04:09 PM
webhead's Avatar
webhead
Oh should also note that when I have everything 'assembled' the gear spins the cable and the speedo registers it...if this has just been FUBAR'ed by the previous owner, and should be replaced to be stock/original, I'm just going to rig something up.
